Oh #%@!! What did I do to my SMC Lipos?
Freezebyte
Oh #%@!! What did I do to my SMC Lipos? - 07.19.2009, 02:02 PM
Ok, I think I just seriously bit the weenie on this one. I just finally got done upgrade my Savage Flux with a new Spektrum DX 2.0 with some Proline Badlands and Velocity dish wheels. I programmed the DX 2.0 as per the usually HPI way and made sure the EPA's were at 125% for throttle and brake, as I was told this would not hurt the motor or the ESC. The throttle only had 10 clicks for trim. I kept the gearing stock at 20/44.
I"m using SMC Sport Max 6000mAh 28C hardcased batteries which have been awesome batteries up until this point. I've been using a Triton 2EQ with balancer at each and every charge and iv'e had the LVC set from 3.0v to 3.2v using the Castle link.
Today was my first day running the new truck and I kept it simple and was just running it in average grass height at a variety of speeds testing out the new tires and rebuilt shocks. I kept checking the temps and I didn't feel the motor, ESC or batteries were getting dangerously hot.
It was working good for around 15 or so minutes when I noticed it started to loose power pretty quickly, more then it used to.
So I shut it down and brought it inside and I about had a cardiac arrest when I took out the batteries that were very warm to the touch and had damn nearly puffed out of the hard pack casings!!
I immediatly put them outside to cool off and hopefully not explode, so I haven't taken a voltage reading on the charger but the LVC was set at 3.1v and it didn't kick in at any point, I just noticed a loss in power sooner then I expected.
Anyone please give me incite or suggestions on what the hell went wrong here? I'm pissed that just ruined $190 worth of batteries and I don't know how or why!
EDIT: Added photo of voltage test results for both Lipos
07.19.2009, 02:39 PM
Well, looks like one or more cells in that pack puffed. Most likely due to the the grass putting addl load on them and they could not keep up. Given their specs they should be able to handle a 168 amps cont, but we all know that the specs are sometimes a bit exaggerated. Plus I have no idea what cells are in there, so you may have just got a defective cell, it happens.
4s setups in heavy monster trucks are just not a good idea. I have stressed higher rated packs that those smcs in a revo on 4s, so I can imagine the savage was pushing them pretty hard. The grass was probably just enough to send them over the edge.
Time for some hyperion g3 packs! Go up to 5s, and gear down to a 17t pinion for the same overall speed. 5s seems to be the sweet spot for the MMM/2200 setup anyway. I ran my lst with the mmm/2200 on 4900 5s rhino lipos (70 dollar pack, 20c rated) and it did fine with badlands, geared for 40mph. Not a light truck by any means, and those batteries had no issues keeping up.
Going up in voltage will reduce the amp draw, provided you lower gearing for the same overall top speed.
Metallover
RC-Monster Spudgunner
Metallover's Avatar
07.19.2009, 04:53 PM
Might have been the new wheels, in addition to the grass. Are the new wheels bigger/heavier then the old ones?
07.19.2009, 05:03 PM
did it roll freely after the new wheels were on? I always "kick" my r/c's before I run to make sure they roll nice. Any drivetrain binding puts serious load on the equipment.
Freezebyte
07.19.2009, 05:32 PM
About same size, but weight less then the other ones.
Yeah, it rolls fine
Theres no way the grass would have put that much strain, considering that i've run the truck with the same batteries on the stock tires with no such issues.
I'd rather not deal with trying to modify/run a 5S pack on a Flux, its not specced for that type of wiring/Lipo.
07.19.2009, 05:48 PM
Not to point out the obvious, but the lipo did puff. They only puff if they go way under voltage and have a large load placed on them, or they are over stressed past their capabilities.
And running in grass places more load than almost anything else (save maybe deep wet sand or mud).
As ML said, use a 3s and a 2s. Heavy trucks need more voltage dude, not talking out of my ass here (even though it would be cool if I could do that).
sikeston34m
sikeston34m's Avatar
07.19.2009, 06:17 PM
Jim Carey did that on that one movie.
Finnster
KillaHurtz
Finnster's Avatar
I did that once on a dare.. was funny for a bit, then just made my tongue taste funny.
Grass is the worst you can put a pack thru. Lots of people think speed runs are really hard on batts, but they are relatively light duty unless the gearing is v. v. tall.
Hard to imagine it got fragged that easy, then again could be the way you drive it or a bad pack. Eagletrees are invaluable things, as are temp guns. Hot lipos are over worked lipos and soon to be dead lipos. Sry.
07.19.2009, 08:28 PM
It most certainly is. Its speced for 4 THROUGH 6s, that means 4,5 or 6. You've just seen everybody pair their lipos and choose 4 or 6s.
You're into it this far, go up to 6s and reduce your gearing for the same top speed as your 4s setup, everything will run cooler and happier.
I know from running nitros how quick the little engines overheated running in grass, so I mostly avoid grass runs with my electrics. Good Luck!
Metallover
Metallover's Avatar
07.19.2009, 05:37 PM
Just use a 2s and 3s pack in a series to make 5s. A hyperion 5000mah G3 vx 2s and 3s lipo.
junkman
07.19.2009, 06:46 PM
have you metered the packs to see what the voltage is now. Maybe something went wacky with the lvc and it just drained them too far.
Freezebyte
07.19.2009, 06:56 PM
I'm afraid to do anything with them in their current state
Wild YFZ 450
yfz 450.
Wild YFZ 450's Avatar
07.19.2009, 07:06 PM
Then throw them out, and Go buy a Hyperion 5s setup....
  Send a message via AIM to Wild YFZ 450
Freezebyte
07.19.2009, 07:21 PM
No, im sending them back to SMC once I hear from them tomorroo
Freezebyte
07.19.2009, 07:32 PM
Added voltage readings
