Hydra HV 180
finfin
Hydra HV 180 - 08.11.2009, 03:14 AM
Hydra HV 180 is using water to cool the ESC, isn't it?
How can i use 2-3 small brushless fans with it? Is it better than water cooling? I can't find water cooling's equipment....
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
08.11.2009, 06:52 AM
what do you plan on using the ESC in?
they are meant for a boat and are set up for a boat castle link wise.
and unless you void the warranty and fit a heat sink directly to the FET's then you are going to have to use water cooling.
hehe you silly duffa...you put a MMM 2200 in a summit
they arnt ment to go fast
  Send a message via MSN to shaunjohnson
Pdelcast
Pdelcast's Avatar
08.11.2009, 03:47 PM
The main issue you will run into is that the water cooling is bonded directly to all the FETs. And air cooling is very inferior to water cooling. I wouldn't recommend it.
Patrick del Castillo
President, Principle Engineer
nitrostarter
nitrostarter's Avatar
08.11.2009, 03:51 PM
Patrick, wouldn't the cooling plates being aluminum act as heatsinks in themselves? Then a fan blowing over them could help as well...
N. Rustler conversion
finfin
08.12.2009, 12:27 PM
Can be like this?
Pdelcast
Pdelcast's Avatar
08.12.2009, 08:48 PM
Originally Posted by finfin View Post
Can be like this?
Nope -- bad idea.
Pdelcast
Pdelcast's Avatar
08.12.2009, 08:59 PM
Better idea --
Wait for the Phx-ICE-160HV. It's an air-cooled monstrosity. We ran one today on a Neu 2230/1Y at 260A for two minutes. We had to run TWO SETS of 6.5mm bullets, because they kept desoldering themselves. We also had to water cool the motor (big pump driving ice water from a 5 gallon bucket through a cooling jacket on the motor...)
After two minutes of this abuse, the controller reached its over-temp limit and shut down -- but in that time it had devoured 8.6AH of charge from the batteries.
It should handle pretty much ANYTHING you can throw at it.
shaunjohnson
i pwn nitro
08.11.2009, 05:28 PM
even so...they have no where near enough surface area on the fins to transfer the heat to the air.
water is the best medium for heat transfer i THINK, takes longer to heat up and can carry the heat well.
08.11.2009, 06:11 PM
Water cooling has been covered in a few 1/5 builds- you can run tubing from the esc to a radiator & pump, and that will cool the water & the esc as it circulates. Only issue is the water cooling setup wont be cheap or small, but it would work fine. Just need to use the special fluid that is non-conductive.
whitrzac
Can't catch this...
whitrzac's Avatar
08.11.2009, 11:14 PM
couldn't you fill it with coolent, cap the holes, and add a heatsink on top??
08.11.2009, 11:32 PM
The coolant would heat up and become useless.
08.12.2009, 09:15 PM
I dunno, everytime you build a better esc, they produce a dummer noob....
Unsullied_Spy
Unsullied_Spy's Avatar
08.13.2009, 03:59 AM
So true. So Patrick, how does it feel to invent better (or rather, worse) noobs?
Will we be able to set up the Phoenix ICE HV controllers for use with a pistol-grip radio? I know you won't warranty it if it isn't used in an aircraft but since when has that stopped us?
shaunjohnson
i pwn nitro
08.13.2009, 04:03 AM
and oh my ferkin god that is one hell of an ESC you built there castle!!
