Could possibly float boat
PedeBasher
PedeBasher's Avatar
Could possibly float boat - 08.13.2009, 06:24 PM
I am going to try to be eco-friendly and green and use recycled foam to build a boat. My dad gets foam by the truck loads (literally) when he unloads lumber trucks and it normally gets trashed and eventually ends up in a dump. Not cool. Its some kind of blue foam, usually 4x4 or 6x4 logs and are typically 8ft long.
My goal is to get a boat that will support 3 people or more (around 500lbs), have storage space, and be able to withstand Lake Michigan abuse. And my budget is about $50.
I should have updates tomorrow.
Did you know?
  Send a message via AIM to PedeBasher
Andrew32
08.13.2009, 06:33 PM
$50 budget?!
haha you mean your gonna build a barge?
riverat1540
riverat1540's Avatar
08.13.2009, 06:45 PM
nah its foam whick means u can shape it however u want, you could build a pretty sweet boat with a good amount of hard foam i would make a rough form and carve it out. best of luck
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
PedeBasher
PedeBasher's Avatar
08.13.2009, 06:46 PM
Not really a barge, more like a jon boat, but bigger.
$50 is only a budget, if I have to, of course I will go over it. I get all my foam materials for free though. That will probably be the only material structure of the boat.
Did you know?
kwik
08.13.2009, 07:01 PM
its probebly stuff called blue core.... its a high density foam sometimes used in RC planes....
would be good to see, are you going to work out how much you need? or are you just gunna through it all together and see what happens?
PedeBasher
PedeBasher's Avatar
08.13.2009, 07:31 PM
Well I am going to work out roughly how much I will need going across and then work my way up. The side of the hull will probably be pretty high and dense.
I am going to be looking at boat hull designs tonight to figure out what I want to shape it after and what would work best for me. Probably either a vee hull like on my jet ski or a catamaran. Both will offer tons of stablility.
Did you know?
riverat1540
08.13.2009, 07:38 PM
id flat bottom it with a front curve just like a jon boat. will make it less tippy and help boyancy
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
PedeBasher
PedeBasher's Avatar
08.13.2009, 11:53 PM
I think I will but also give it a small vee slope to make it a little more controllable.
So far it looks like my dimensions are going to be 8' by 4' and a half. Id love to add a cab to it, and possibly a small storage cabin underneath. I will also have a rudder and possibly have it hooked up to a steering wheel.
Did you know?
Andrew32
08.14.2009, 10:27 AM
are you goign to somehow seal the foam? i guess i just dont understand how dense this stuff is....do you tink itll push in with the weight of people on it?
08.14.2009, 02:35 PM
Yeah, you want to put at least 2 layes of fiberglass on the outside, and I would do the inside too. Basically foam core that way. FG is not cheap, but you will have a robust structure.
kwik
08.14.2009, 02:49 PM
pedebasher... do whatever floats ya boat... sorry, i had to say that :P
how is it powerd? padels? and i asume your going to have a rudder right?
good luck on the project, and get some pics up after, would be great to see this... and maybe the "skin" could also be something recycles... thin aluminum maybe or some plastic sheet from something....
PedeBasher
PedeBasher's Avatar
08.14.2009, 03:18 PM
How about just fiberglass resin? I recently acquired some with some cabasil. Would that work?
I would love to do something recycled for the skin. Could I possibly melt down some kind of plastic? Maybe use a heat gun to flatten lexan bodies and glue them on?
Did you know?
08.14.2009, 03:20 PM
Some giant heat shrink would be cool! I agree with using a recycled product. Used be called "being cheap", now it is called "green"...
I am building a storage shed at my shop right now. Dimensions will be 10x21. Odd size, but I had a tarp canopy frame (separate tubes that slip fit together) that was not being used. Decided to weld that up and add some bracing (more tubes that I had). My buddy pulled up a deck, and gave me the old lumber, 60+ 2x6x12' treated boards. My other friend gave me some old thick wall 3" water pipe, I cut that down and concreted 12 3' pieces in the ground for supports. Bolted some of the lumber to the pipes and used the rest to make a "deck". Flipped the old boards over so the good side faces up, looks like new! Another friend frames houses, so he gave me most of the scraps from the last house, I almost have enough to frame the walls, then i will bolt the canopy top to them and use some old sheet metal siding (came off my building during the storm) as the roof. So far i have about 150 bucks in it, mainly nails, bolts, and saw blades. I consider this being cheap!!! but I would rather not spend my money, and used lumber is just as good to me. I priced new lumber/materials and would easily go over 2 grand....
jayjay283
jayjay283's Avatar
08.14.2009, 08:04 PM
Lake Michigan has worse currents than pipeline. I grew up surfing Cali and dont trust the Michigan lake under toe or currents 1 bit. I take a sip of the lake everytime I see it because I can't believe it isn't salt water.. maybe a little river cruiser or behind the breakwall boat maybe to look at boobs by Navy pier. I can swim quite well Ill go past the break wall to test it LOL... can we bring my wife ? She is rican born on the ISLAND and cant swim. Pathetic huh
PedeBasher
PedeBasher's Avatar
08.14.2009, 08:38 PM
Haha. I trust the lake like no other. I have a private beach and no breakwater so I cant really have a breakwater cruiser. The current is only ever bad near me during either A, storms or B, windy days. Both not often occurrences. If it gets bad I can set anchor. Meh.
Tonight I think I will start a long, short centerboard. I didnt get any foam today but Monday I hope to have some more. I should have pics of my plans, progress tonight.
Did you know?
