Neu 1515 Heatsink with cooler?
Kajman
Kajman's Avatar
Neu 1515 Heatsink with cooler? - 08.19.2009, 03:09 PM
Hi
Can anyone advice me where to get something like that? That simple thing seems not to be that easy...
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.19.2009, 03:44 PM
Why do you want a heatsink w/fan for a Neu motor? Do you have a smooth version can? If so, why?
Generally, you should never need a heatsink/fan with a Neu, even a smooth can version, if run within typical circumstances.
You need to tell more about your setup, what motor (# of cells, and Kv.), vehicle, gearing, weight, temperature where you live.
You mean a water cooling jacket, or just a normal finned heatsink for a smooth can neu?
Both exist....
Kajman
Kajman's Avatar
08.19.2009, 03:59 PM
Ok guys, normal finned heatsink for a smooth can neu :)
It is 1515 1.5d 2700kV in Emaxx, MMM on 6s2p a123 cells. Gearing 21/68, overall about 16:1 as far as I remember internal of #3905 emaxx. Weight by 5kg.
On sunny day (30deg centigrade), whenn killing my batteries Neu gets quite hot, I would like it to live as long as possible and drive without cooling brakes other than changing batteries :)
08.19.2009, 04:32 PM
That'll be why you need it- the 2700kv is an amp hog, you shouldnt run it on that much voltage (equal to 5s lipo), 4s at most except for short speed runs with cool down periods.
http://www.airpowernet.com/twe3/prod...products_id=88
http://www.tamjets.com/original/prod...a9d0aed891f9dc
Huzzar...
Kajman
Kajman's Avatar
08.19.2009, 05:01 PM
Thanks man. Voltage is ok, a123 drop down quite a lot under pressure, 2200 was to slow for me :) When I geared it up, it was hot too.
OZ-RUSTLER
OZ-RUSTLER's Avatar
08.19.2009, 05:30 PM
http://www.impaktrc.com/product_info...oducts_id=4036
Kajman
Kajman's Avatar
08.19.2009, 05:38 PM
Seems to be nice, question if it fits emaxx :) But it is big!
Kcaz25
Kcaz25's Avatar
08.19.2009, 05:39 PM
How hot?
Kajman
Kajman's Avatar
08.19.2009, 05:40 PM
75 degrees centigrade
08.19.2009, 09:15 PM
What I need is a little Samuel L Jackson picture with the caption "English mother f**ker, do you speak it?!"
76*C = 167*F....
Im so used to Fahrenheit now that Centigrade or Celsius means nothing to me hardly...
zeropointbug
Z-Pinch racer
08.19.2009, 11:28 PM
LOL
167F is not that hot, within the safe limits, but personally I would not like to run that hot day in day out. So, yes, I would get one of those heatsinks for it, you should not need a fan, however, and even if you did use one, it will likely break soon anyways.
Kajman
Kajman's Avatar
08.20.2009, 01:26 AM
Yeah, I will get it, one of heatsinks and high rpm fan on it. Good is, that autumn is coming and outside temperature will be much lower, which will let me have fun longer.
I don't really understand one thing, people run 2200kV geared for this speed and claim to have lower temperatures, I have checked different motors within kv range 2000-2700 and gearing vs. kv for the same speed gives similar temperatures for me. Why should it be different? Eagle tree logs would say something, but I don't have logger.
BLBuggyBoy
08.20.2009, 11:18 AM
lower kv and higher voltage= lower temps due to less amp draw and amps is the amount of electricity flowing, voltage is just the "pressure" behind the electricity, im using the old water hose analogy lmao im a electrical engineering major what can i say lmao
Kajman
Kajman's Avatar
08.20.2009, 12:38 PM
yeah, but having the same voltage (I 21v as I will not change batteries) when we use low kV motor with harder gearing and high kV motor with lighter gearing you will get similiar motor temps...
