weight distribution for racing (BL Revo)
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
weight distribution for racing (BL Revo) - 08.19.2009, 04:09 PM
I am doing some last minute rebuild on the Revo for the race weekend, and I was going to make a new, lower CoG battery mount. I was going to move it forward, and down, to bring the front/rear weight distribution to around 50/50. I know in the real world 50/50 is ideal, and makes for a very forgiving and predictable ride (ex. Mazda RX8).
But I am just not sure about this... currently the battery is placed right side, far back as it can go.
Is there anyone with some direct experience that can comment on what weight distribution is ideal for a Revo on the track?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.19.2009, 04:17 PM
I myself am getting ready to do a 3.3 conversion and curious about the very same question ?
What motor mount/tranny have to elected to run with for racing ? I'm undecided weither to just get a RCM motor mount and use the stock tranny with a center diff or go w/a Erevo trans to simplify the conversion ??
zeropointbug
Z-Pinch racer
08.19.2009, 05:22 PM
My setup is as follows:
1512/3D (1700kv)
6s lipo packs - 4200mah each (HP VX, & HP VX G3's)
Quark 125 - modified
Gmaxx single speed
HERE is a pic from awhile ago.
The current left/right balance is biased to the right side a bit. So if I lower the battery and keep it far back, then the rear of the truck will have the mass down low, and the front will have mass up higher. I am wondering how this will affect the driving feel.
BB16, could the nose diving off a jump be because you don't throttle it right off the peak of the jump?
brushlessboy16
brushlessboy16's Avatar
08.19.2009, 04:31 PM
i ran my battery up fron on a tray mounted where the right steerig servo went.
according to traxxas the revo is setup about 60/40 with more weight to the rear.
My setup was 50-50 and the truck constantly nose dived off jumps- i dont know if it was weight distribution or what.
left/right balance was spot on also.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.19.2009, 06:44 PM
Looks good, Thats pretty much what I'm thinking. I might go with the stock trans w/a 1/8 scale diff so I can keep F&R servo brakes. Just need to figure out much like yourself the weight balance ?
Thanks.
crazyjr
crazyjr's Avatar
08.20.2009, 10:57 AM
Here is a racing revo using the new Emaxx tranny, I know its not the same, but you might can get some ideas
http://www.rc-monster.com/forum/showthread.php?t=19479
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.20.2009, 12:04 PM
Read the whole thread, thanks for making my decision all the harder now. Good info thanks !
crazyjr
crazyjr's Avatar
08.20.2009, 08:36 PM
Sorry, he was using a nitro chassis, so i thought it applied. good luck on your decision
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.20.2009, 09:10 PM
It did apply and I am also.
It was sarcasism my friend, for making my desicion all the harder as to what I was going to do . Sorry for the confusion.
I think the easy cheapest way out for my application will be to use the stock 3.3 trans,I already have a TRX CD installed w/500000wt. Just gonna get a RCM motor mount I reckon and make a battery tray.
Thanks
zeropointbug
Z-Pinch racer
08.21.2009, 01:30 AM
I am literally going crazy trying to come up with a lower cg setup, but I can't seem to do it. Each time I think I have it, some component won't be able to fit or be able to mount in the required area. The Quark is the main problem with the short 10ga bat leads coming off one side of it, and the generally larger than normal size/weight of it.
I only have until tomorrow evening to do what I can do before practice in the evening, and that's after me having to drive 200km to the track location. I also was expecting an order to come in from Tower that includes some LPR rims, rpm true track arms, and a few other replacement parts. I sure as hell hope they arrive here tomorrow!
I should have just got the E-Revo chassis....
nitrostarter
nitrostarter's Avatar
08.21.2009, 11:01 AM
Thanks
Definitely the easiest way. Balance is pretty close as well with these setups.
I did a 2.5 conversion. I used RC-M mount, Tekno tray, tekno rx box, and JB welded the Revo tranny in 2nd. I removed the mechanical brake and made a plate to mount my MMM right there. This way the motor and mmm on the left side countered the battery and electronics on the right side. Front to back wasn't off by much as well. But I also used the 2.5...
I have a couple motors for sale that would scream in a Revo conversion...
N. Rustler conversion
08.21.2009, 09:10 AM
The Revo I just sold looked like this....
http://www.rc-monster.com/forum/showthread.php?t=23032
Same basic set up as the above post. It seemed v/well balanced using the 3905 trans and 2 batts.
jzemaxx
08.21.2009, 12:46 PM
That is my truggy/Revo and its very well balanced. I have raced it all season.....love it.
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
