Cen diff upgrade
plaviblue
plaviblue's Avatar
Cen diff upgrade - 09.19.2009, 10:47 AM
Is any one has info on the cen diff upgrade, could you post links here. I have looked through the thread and cannot find the info I need.
thanks guys, btw, just took out the front and rear diff this morning, that makes a total of 13 times!
FLM Extended Savage -Nue 1521 2d MMMv3 6cell
E-Maxx -Flm Parts stock motors (the wife's)
Slash -MM medusa 3300k 3cell 68 mph!
[B]Custom FLM Axial Crawler
Losi Rammunition 1/184600k
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
09.19.2009, 11:55 AM
Theres a few threads on this topic, you'll have to search through these to find what your looking for but it's there.
http://www.rc-monster.com/forum/sear...archid=1333044
Finnster
KillaHurtz
Finnster's Avatar
09.19.2009, 12:53 PM
My complete how to
Nard Cox
n00b
09.19.2009, 05:23 PM
Here another Cen Diff mod showcase.
But I wouldn't go for Cenns now the HPI Bulletproof Diffs are out and they are selling for only $25 per set. Only heard positive stories so far. People say they are almost like Cen Diffs only with better machining quality (HPI > Cen).
I'm currently also running the Cenn Diffs because the stock diff pinions broke (both front and rear at the same time) and they are holding up fine so far.
plaviblue
plaviblue's Avatar
09.20.2009, 06:27 PM
The HPI diff does not come with the spider gears and that is the weak link in mine. Have never broke the actual diff gears yet.
Finnster
KillaHurtz
Finnster's Avatar
09.20.2009, 12:36 PM
The think I like about the Cens are the spider gears are much harder and stronger than the HPI ones. The pinion and ring are cast tho, and not machined like the HPIs.
The diff ratios are different as well. You shouldn't need to shim the HPIs so much like the CENs then also.
Depends on all you are looking for, but the new HPI gears are a very welcome upgrade
Finnster
KillaHurtz
Finnster's Avatar
09.20.2009, 09:18 PM
The ideal diff would have the Cen spiders w/ the new HPI R&P gears imo.
Gee
A Horse's Ass
Gee's Avatar
09.20.2009, 10:40 PM
The one nice thing about the cen ring and pinion is your shim job doesn't have to be perfect. You can get away with a little play vs the XL stockers. Any play left in the stock setup and there goes another 13 dollars for a 13t pinion. I finaly threw away all the broken ones I had lined up like dead solders. I've been running the cen ring and pinion on the XL alum cup and gears. http://www.rc-monster.com/forum/showthread.php?t=21219
The only problem so far was my screws backing out of the cup and breaking off. I need to get a new cup, I've been using a plastic diff cup from one of my rcs so I could get my Savage fix. A little more time to let the loc-tite set probably would have helped. Sound like the new HPI cup are a reasonable price and nothing to mod either.
Finnster
KillaHurtz
Finnster's Avatar
09.21.2009, 12:55 AM
How close was the fit? They seemed just a bit off when I modded mine, but don't recall exactly. If I could put the hpi R&P on the Cen diff I would (assuming I break mine anytime soon)
Gee
A Horse's Ass
Gee's Avatar
09.21.2009, 01:18 PM
Which part?
The holes needed to be oblonged (is that a word?) out so the screw would sit flush but once that was done the screws went in straight. The ring gear is real tight on the cup I ran the dremel and a grinding stone around the XL cup a couple times so it was easier to install. They fit into the bulkhead without any modificiation.
plaviblue
plaviblue's Avatar
09.24.2009, 09:59 PM
This was a big help. Thanks guys!!!! Should have a drop in FLM version soon.
