Brushless 380s for a Tamiya tank...
Nautilus
Brushless 380s for a Tamiya tank... - 10.20.2009, 11:08 AM
So I am getting a Tamiya tank 25 years after I initially wanted one. The tank uses two brushed 380 motors for locomotion and turning the turret.
I was wondering if there are suitable high torque/low rpm 380 sized brushless motors out there? I do not want increased wheel speed, as I do not want to risk stripping any of the gears. I want brushless simply for low maintenance and efficiency. To the extent I can increase torque without an increase in wheelspeed, that would be good too.
Thanks.
Nautilus
10.20.2009, 04:00 PM
Thanks.
Eh. Nevermind. It appears that the Tamiya esc (which also coordinates with a sound unit and can't practically be switched out) only works with brushed motors.
10.20.2009, 04:31 PM
Naturally- stock brushed electronics in 99% of tamiya's gear. Given the low speed nature of the setup, I dont imagine maintainence will be much of a problem- 380 motors are dirt cheap too so replacing them every so often is no big deal.
Nautilus
10.20.2009, 05:10 PM
true, but accessability in most of these tanks is a PITA.
I'm sold on brushless/lipo and not just for sheer horsepower.
10.20.2009, 09:53 PM
You can get some cheap ones on hobbycity. Check 'em out.
www.hobbycity.com
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.20.2009, 04:50 PM
The 370 & 380 brushed motors are purty inexpensive, I'll bet they'll take a lot of running befor needing replaced.
Example; http://cgi.ebay.com/RC18T-RC18R-MINI...item5ad40dfa6f
TexasSP
Something, anything, nothing
TexasSP's Avatar
10.20.2009, 10:02 PM
I have an HL 16th scale tank I will be putting brushless in in the future. Each motor will be controlled independently with each stick and I will be using two sidewinder micros and the lowest KV motor or possibly a small outrunner.
It can be done you just have to change it from how most tanks are done and ditch the stock electronics.
www.cubicle101.com
