want more flex 4 the pede -
11.28.2009, 06:07 PM
so ive been messin round with the suspension on my pede and iwant to get more flex out of it but ilke the stance of a rustler wat can i do to get both but be strong enough to launch into the air and take a hard landing? i really want to do the wide pede conversion but still havent found a some what cheap way to do it. and neil i have read the thread on the wide pede conversion on byt..
BL Pede, Integy aluminum steering linkages, aluminum shock caps, RPM camber links.
Never Replace Always Upgrade!
11.28.2009, 07:21 PM
put losi 8ight front shocks on it, they will handle any junp you can throw at a pede
Originally Posted by Semi Pro
Originally Posted by BrianG
11.28.2009, 07:44 PM
that'll gimme more flex and the stance of a rustler?
i pwn nitro
11.28.2009, 07:53 PM
by flex do you mean suspension travel?
the pede is a pretty unstable truck as trucks go, but it is fun to play with.
like semi said.
get some losi 8 shocks on it. they are loads better!!
or you could get the traxxas big bore shocks and get some hot racing multi-rate springs, heavy for rear and medium for front, makes a huge difference!
Fat Kid Engineering
11.28.2009, 08:20 PM
I use Ofna 1/8 buggy front shocks on the front and rear on my FLM Stampy, got the set of 4 for under $30.00 via Fleabay.
If you want the stance of a Rustler, you'll need shorter shocks than the stockers. Try Jato shocks ???
11.28.2009, 10:18 PM
I think he would need to just lower the body, by using Rustler body mounts, to get a Rustler look. If you use Jato shocks all it will do is make the truck itself lower, and it will kill its ability to jump.
11.29.2009, 12:24 AM
pedebasher did u ever send those screws? curious... i dont want to kill my jumping abilities
11.29.2009, 01:49 AM
Sh!t! I totally forgot dude. Sorry. Hope I didnt keep you at a halt in terms of running.
Just do what I said, and get some Losi shocks. The Rustler body mounts will really give it a sick stance.
Fat Kid Engineering
11.29.2009, 09:22 AM
Losi shocks with the bottom plastic cartridge style will not handle the bigger jumps as well as Associated T4 shocks !? Ben there, done that.
11.29.2009, 02:50 PM
no u didnt pedebasher im waitin on batteries ill look into the body mounts thanks guys just let me know when u send them out so i can look for them
Fat Kid Engineering
11.29.2009, 08:43 PM
Check this out, might be a cheap deal for a set of 4 ??
http://cgi.ebay.com/NEW-Team-Associa...item25576ff0cf
11.30.2009, 07:53 AM
t4 shocks are not going to handle jumping duty better than losi 8ight shocks. You are comparing a 1/8 scale shock to a 1/10 scale t4 shock. There is no comparison.
Though i used to love my t4 factory team shocks they are not better than losi 8ight shocks.
Fat Kid Engineering
11.30.2009, 09:07 AM
Dude, I know. I'm not a F-in idiot ?
But if the guy is one a budget, and wants scale appearance they would be the ticket.
It's only a suggestion.
11.30.2009, 12:52 PM
Thanks Bondo! lol
11.30.2009, 12:56 PM
you cant put rustler body mounts on the front of the pede because the servo is in the way
someone correct me if im wrong but i have the rusty body mount and just couldnt get it to fit without some wack modifications.
the rear body mount isnt a problem because you just neeed to take off that extender peice.
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
