Castle 1717 in the LST
Castle 1717 in the LST - 12.15.2009, 06:05 PM
Ok so after I turned the shaft to 5mm I figured I would give it a try in the LST with the TDR mount. My TDR mount is setup for m3 thread screws with a 25mm spacing, the 1717 uses m4 screws with a 25mm spacing. I have a RCM neu front cover that I modded a while back to accept m4 countersunk screws to bolt onto the motor. It hasm3 threads spaced 25mm apart so I used some short m3 countersunk screws to mount it to the TDR plate, after I mounted the 1717.
I need to get another TDR mount, so I will have "the dude" drill and countersink the front plate for m4 size screws. Turns out my new 1521 1y also has m4 threads, so maybe I will have him make me 2 of those plates...
Anyways, here are some pics. The spur is a 59t, and the 25t pinion will not mesh quite close enough. This is not due to lack of adjustment in the mount, the 1717 contact with the tranny "foot". I can cut the "foot" down about 1/8" and re-drill the hole in it and in the chassis to gain the necessary clearance. However a 63t (stock lst 2nd gear) spur should work fine without any mods to the tranny.
Pic time!
12.15.2009, 06:20 PM
Here is the speed calc result. 42mph is not too bad, wish I had some larger pinions... Guess i could mod the tranny and use the 59t spur. That would get me around 45mph. Or use the xxl tranny internals...
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1.9130434782608696
Spur Tooth Count: 63
Pinion Tooth Count: 25
Total Voltage: 22.2
Motor KV: 1577
Tire Diameter (inches): 6.5
Tire Ballooning (inches): 0
Spur/Pinion Ratio: 2.52 : 1
Total Ratio: 15.94595 : 1
Tire Circumference (inches): 20.42 inches (518.68 mm)
Rollout: 1.28:1
Total Motor Speed: 35009.4 RPM
Vehicle Speed: 42.46 mph (68.2 km/h)
redshift
RC-Monster Square Tube
redshift's Avatar
12.15.2009, 06:25 PM
You sure that's gonna be enough motor?
Haha if your spur ever locked up I think that motor would just spit the whole trans off!
Looks trick, I REALLY think Castle should offer a step shaft.
I'll be praying for your entire driveline....
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.15.2009, 06:36 PM
OMFG, That 1717 dwarfs the tranny !
Anxious to hear feedback after you drive it, should be SICK.
12.15.2009, 08:36 PM
It is a big motor. Fits well on the tdr mount. I have a feeling geared for low 40s it will be a best. Most likely will end up in the 6x6 lst, as that truck will be heavy and geared lower. The 1521 1y is plenty for a lst, but I could not resist giving the 1717 a try in a lighter vehicle.
Semi Pro
Semi Pro's Avatar
12.15.2009, 11:26 PM
looks great, im just waiting on some parts from TDR befor i get to mount mine
12.15.2009, 11:45 PM
They have 20% off right now, I just picked up another mount and a spare m4 sized center piece.
J57ltr
12.15.2009, 11:59 PM
I like that motor it looks like a Fosters can.
Jeff
Desert Rc
12.16.2009, 12:48 AM
Thats badass!!! the can is almost the same width as the chassis....PERFECT!!!!!
12.16.2009, 12:56 AM
Jeff
Funny, that was my beer of choice back in the day!
J57ltr
12.16.2009, 01:04 AM
I have been looking at the Castle lineup and thought they ought to give them beer names like Tallboy, Little Kings, Fosters, and the 8 oz.
Jeff
Semi Pro
Semi Pro's Avatar
12.16.2009, 07:34 AM
yep i grabbed a single speed adapter and a m4 center too, sucks that he is out of the 6mm cullets
12.16.2009, 10:55 AM
Well if you are going to get into wine how bout Thunderbird.
Jeff
I used to drink that in college, oh the headaches!
Originally Posted by big greg View Post
i think you could gear this thing for 60 with that motor, running it on 6s james? this thing is going to be ganster! ha
yep, just need bigger pinions, or tires!
yeah, I was going to grab one of those collets as well...
12.16.2009, 04:16 PM
you've gotta have some cen tires somewhere...
12.16.2009, 05:31 PM
I have both, the chevrons and the bowties... Not sure if i want 4lbs of wheels/tires on my truck though! I really need to sell some tires, I have 3 26 gallon totes full... Must be at least 100lbs of wheels/tires...
