Jammin SCRT10 -
12.19.2009, 06:48 AM
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
More Pictures -
12.19.2009, 06:50 AM
More info, wide plastic 46T spur, comes with a 13T Mod 1 pinion and a bore reducer for those that want to run smaller motors with an 1/8 shaft.
A few more pictures.
tires
motor mount
center diff with plastic spur.
side
12.19.2009, 11:27 AM
nice ride man!!
i think of all 4wd trucks until now the jammin is the most racer of all from box...
letīs see how it handles on track!!
regards
Update -
12.19.2009, 02:02 PM
Started working on putting the kit together. Added a Mamba Max and Neu 1509/2D motor. Good news is most of the parts are the same as the CRT.5 so I am moving over a bunch of cnc parts (steering rack, spindles, c-hubs, wheel hex, etc). This also means replacement parts will be easy to get since the CRT.5 has been out for a while. Bad news (at least for me) is that the Battery will only hold a 2s lipo pack. I guess this is ok if you will be running a smaller brushless motor and 2s, but I want to use my Neu 1509 on 3s. I was running the Neu and 3s in my modded CRT.5 and it was a rocket and ran very cool, so I moved my custom carbon fiber battery tray over to the SCRT10 so I could use a 2s or 3s battery.
Optional parts
CRT.5 compared to the SCRT10
The Neu 1509 is slightly bigger than a castle 5700 motor.
My custom battery tray, uses the existing holes in the chassis.
Here is a Protek 2s and a Losi 3s all 5000mah. Only the 2s will fit in the stock tray. My Reedy 2s hardcase also fits in the stock tray.
12.19.2009, 02:04 PM
Originally Posted by timaneli
nice ride man!!
regards
Yeah I can't wait to get out on the track. My CRT.5 was one of my favorite trucks, so the longer SCRT10 should be sweet.
12.19.2009, 02:20 PM
Looks good, didnt expect it to come with the pinion and bore reducer, nice features :)
Cant tell But are the suspension components- Aside from the shock towers- the same as the crt.5
12.20.2009, 04:17 AM
They seem to be exactly the same as what is on the CRT.5 pro. aluminum shock bodies, screw type adjusters, alloy/plastic shock cap.
RC carbon junkie
12.19.2009, 02:22 PM
Is the chassis plate from the original nitro CRT.5?
SC8-E RCM MMM CC 1717
Slash 4x4 MMP CC SC 2400
12.20.2009, 04:19 AM
It looks like a stretched CRT.5 chassis. Has the mounting holes in the chassis for the nitro parts (not used).
Update -
12.20.2009, 04:20 AM
Finished the body, just a super fast rattle can job, I normally use faskolor but that paint takes weeks to cure and I wanted the body dry so I could get it out on the track tomorrow. I installed the battery tray, motor, esc and tested it on the work bench. One thing I did notice was the stock tires are pretty hard (compound) and much smaller than what others are running. See the picture where I compare the stockers to some Pro-line bow ties for an Associated SC10.
Quickie paint job
Battery tray that fits 3s lipo
Neu 1509 motor and Mamba Max esc
Stock tires and pro-line bow ties (Associated sc10) the Bow tires look wider than normal because there not mounted, but you can see how much taller (larger diameter) they are.
12.19.2009, 06:47 PM
How much longer is the chassis than your crt.5
12.19.2009, 07:04 PM
stock crt.5 has a wheelbase of 8.8in
Scrt is 12.75in
12.19.2009, 08:26 PM
I'm thinking of picking up that plastic spur for my CRT.5 to lighten things up a bit.
KillaHurtz
12.19.2009, 10:49 PM
What would it take to convert a .5 to a SCRT? Looks like mostly a longer chassis and a the bumper/body mounts. I like some of the hardware a bit better on the .5 (towers, CD mount mostly, does it have plastic knuckles?) but looks GTG.
How long is Mike's .5 chassis?
RC carbon junkie
12.20.2009, 10:31 AM
So is this SCRT10 the clone version?NH has 2 listed forsale/backorder.
Hybrid Mode
