charger ???????'s
anthony213
charger ???????'s - 12.31.2009, 12:45 PM
need a good charger , 1 that charges up to 6000 mah and does 2c charges . what do you guys recomend ?
Metallover
RC-Monster Spudgunner
Metallover's Avatar
12.31.2009, 12:51 PM
I love my Hyperion. I have the 0610i which does up to 6 cells at 10a at 250w. Wattage is what you need for large packs. 22.2v(12a)=266.4 watts. Make sure your power supply is up to it too.
Also look at the TP1010c, FMA chargers, and a few others.
bdebde
That's All Folks!
bdebde's Avatar
12.31.2009, 03:45 PM
Check out the Ichargers, I just got one and it is great.
12.31.2009, 04:08 PM
Just looked at those and the 20A model would be sweet if it could do 2 batts at once. With 20A and 350W it should be able to handle it, but, the programming is probably not set up for it.
The chargers look nice though
bdebde
That's All Folks!
bdebde's Avatar
12.31.2009, 04:37 PM
The balancer boards (sold seperately) allow up to the max cell charging; 2 x 3s on 6s model and 2 x 4s on 8s model and so on, just need a y cable on the main lead.
hoober
01.01.2010, 12:12 PM
12 amps is what you spec. If you'll put up with 10 amps (there's many chargers with a 10 amp limit) then for 2S you may like the 989 MRC superbrain. For 3S you might like the Checkpoint TC 1030. There are also many Chinese chargers that will do 2-6S at 10 amps. (i-chargers are one)
Erevocanuck
01.01.2010, 08:52 PM
Alot of the lipo battery companies say not to use the MRC chargers because they don`t use the constant current/constant voltage standard of charging
