really bad virus....i need advice
scarletboa
scarletboa's Avatar
really bad virus....i need advice - 01.26.2010, 11:02 PM
while using the google search engine, somehow, a "antivirus trial" automatically started doing a "scan" on my computer and "found" about 50 viruses.
now, whenever i try do do ANYTHING, it says for example: "application cannot be executed. the file taskmgr.exe is infected. do you want to activate your antivirus software now?" it said that when i tried to open up task manager. on top of that, it keeps opening up internet explorer (i normally use google chrome) and automatically goes to porno.org, porno.com, adult.com, and viagra.com. it has about 50 tabs of that open right now. it also keeps saying "infiltration alert, your computer is being attacked by a virus, do you want to block this attack?" i unplugged my internet adapter as soon as it started acting up.
also, a new little red security sheild thing in the task bar on the right with the x keeps popping up at a rate of about 2 per second.
the only thing the computer will let me do is go to the "antivirus" website and buy their product. i can't even turn the pc off without holding the power button down.
i noticed that when i restart the computer, the "antivirus" program is one of the last things to open, so i quickly started a real virus scan with avira antivir before the "antivirus" could start. even though i had to keep clicking resume scan every 5 minutes, it finished the scan and found nothing.
i am using my laptop right now and my desktop is the one that is infected
HELP!!
01.26.2010, 11:14 PM
Start the PC up in safe mode, run a scan, then delete whatever it detects. You may need to go digging manually too- will be in the programmes file but may be embedded elsewhere- download Malwarebytes and that should get rid of the rest of it.
What settings do you normally have your security and privacy at? I keep mine at medium-high with a few custom tweaks and rarely have any issues, havent for a long time. Make sure you download windows defender from the microsoft website if you havent already, nifty tool that lets you decide what runs at start up and what doesnt, alonf with detecting nasty stuff and stopping it from running usually. Crapcleaner is another ultility useful for removing registry entries after the nasties are deleted from the computer..
01.26.2010, 11:17 PM
That's not technically a "virus", but whatever. Anyway, this sounds just like what happened at work around Christmas. At that time, AV software didn't detect it, so we had to remove it manually through trial and error. Try booting into safe mode and scanning the system using whatever AV software you are running. When you boot into safe mode, make sure you select the option where you have network support so that you can download any AV updates.
What is the name of this "software"? If it's what I think it is, there'll be a blue shield icon in your system tray.
scarletboa
scarletboa's Avatar
01.27.2010, 01:22 AM
that's exactly what it is. the blue shield thing isn't visible after a few seconds after the program starts after start-up because it is soon replaced by those red shields with x's.
how did you combat it? my avira antivir couldn't detect it.
01.27.2010, 10:47 AM
If it's called "Antivirus Live", this should kill it. This is what we used at work and it fixed all the computers with it.
1: Reboot the PC in safe mode: As soon as the PC gets beyond the BIOS POST screen, press the F8 key (maybe repeatedly). When a “DOS” menu appears, select “Safe Mode”. This step is needed to make sure the virus is not loaded into memory, which would make it impossible to remove otherwise.
2: Once you are able, log in as the user experiencing the issue. This virus can run under all users, but since most computers are operated by a single primary user, this issue is most likely confined to that user. If more than one user has been operating the machine, steps 3-7 must be repeated for each user.
3: Run Regedit: Click Start -> Run -> type “regedit” and hit “enter”.
4: It is advised to back up the registry hive affected, but I did not. If you wish to do so, highlight “HKEY_CURRENT_USER”, go to file, export, and save it.
5: Delete the following registry keys:
HKEY_CURRENT_USER\Software\AvScan
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Download -> “RunInvalidSignatures” = “1″
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Internet Settings -> ”ProxyOverride” = “”
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Internet Settings -> “ProxyServer” = “http=127.0.0.1:5555″
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Associations -> “LowRiskFileTypes” = “.exe”
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Attachments -> “SaveZoneInformation” = “1″
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Run -> “[RANDOM CHARACTERS]”
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Run -> “[RANDOM CHARACTERS]”
The virus program may not be listed in one of the last two entries above. It will definitely be in one place, but maybe both.
6: Remove the following files:
For Vista:
C:\ Users \ [user] \ AppData \ Local \ [RANDOM CHARACTERS] \
C:\ Users \ [user] \ AppData \ Local \ [RANDOM CHARACTERS] \ [RANDOM CHARACTERS]sysguard.exe
C:\ Users \ [user] \ AppData \ Local \ sysguard.exe
For XP:
C:\ document and settings \ [user] \ local settings \ Application Data \ [RANDOM CHARACTERS] \
C:\ document and settings \ [user] \ local settings \ Application Data \ [RANDOM CHARACTERS]sysguard.exe
C:\ document and settings \ [user] \ local settings \ Application Data \ sysguard.exe
7: Reboot the computer normally, log in as the user again, and check task manager for any questionable processes. Also open Internet Explorer and make sure other websites are available (Yahoo, rcm, etc).
scarletboa
scarletboa's Avatar
01.27.2010, 06:19 PM
that's exactly what it is. antivirus live
i'm not a complete pc noob. i just forgot how to do safe mode. i am pretty familiar with the registry and task manager, so now that i have that list of commands, i'm sure i'll be able to kill this thing.
redshift
RC-Monster Square Tube
redshift's Avatar
01.26.2010, 11:22 PM
Yeh Brian it's like some waste-of-oxygen hacker's version of a RickRoll. Not much compared to what I had back in the summer... consider yourself lucky boa.
FullMetalGrave
FullMetalGrave's Avatar
01.26.2010, 11:24 PM
I run a couple programs in tandem to get as much as junk out as possible. Malware Bytes (per Neil) as well as Spybot and Hijack this. Usually between the 3 programs that will take care of it. As Neil also said, you will probably have to manually remove some junk files.
01.26.2010, 11:38 PM
Also, if this virus is what I think it is, it's a "per-user" thing. If you log in as someone else, it won't be active, so you have an easier time removing it without going into safemode.
JThiessen
JThiessen's Avatar
01.27.2010, 12:30 AM
I think my daughters laptop came down with that same one, or similar a couple weeks ago.
I ran through it in safe mode and couldn't get anything. It actually turns off Norton and Spyware Dr when not in safe mode. I hadn't thought of downloading Windows Defender. Can you do that in safe mode?
snellemin
2 KiloWatt RACER
snellemin's Avatar
01.27.2010, 01:27 AM
I've seen a couple of times on different systems. Sometimes it can be removed without too much headache and sometimes it gets removed but will keep rebooting. Waste of time trying to removed it. So I just swap in a different harddrive and reinstall everything. Once done I just copy over my data from the previous drive.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
01.27.2010, 02:30 AM
exact thing that just got me a week or two ago. I hate that crap.
scarletboa
scarletboa's Avatar
01.27.2010, 02:40 AM
would system recovery fix this?
how do you do system recovery? i'm not too computer savvy......
also, how do you start windows in safe mode? (yeah, i know, i am a total pc noob)
btw: the os is windows xp
Not knowing
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Not knowing - 01.27.2010, 04:06 AM
Not really knowing how to do stuff on the PC can be a fatal mistake. Find a friend, relitive, buddy or whatever who knows this stuff and get them to help you out. I keep my PC friends close so if I end up with an issue that I either cannot recover from or fix on my own I give them a call and all is well.
It sounds like you opened something right before this thing hit you. So it would make sense that whatever you opened is causing the problem. You either opened or downloaded something to let this moron in. Figure out what you did and zero in on that email, program, or file and remove it. To get into safe mode when you press the start up button as soon as the first screen pops up press F5 or Control Alt Delete and it should open to safe mode. Be careful you do not change anything that you do not understand or you could end up in even bigger trouble.
I would get someone else in to show you how to do these things first. Learn from the pros. We can do allot of things with our PC's once we are shown exactly what to do once or twice. Good luck with that.
SUPERMAXX YOUR LIFE.
JThiessen
JThiessen's Avatar
01.27.2010, 10:40 AM
I assume you are referring to "system restore"? In the case of my daughters pc, it wouldn''t run System restore, even in Safe mode. Somehow, it disabled it.
