Cut the shaft???
virusss
virusss's Avatar
Cut the shaft??? - 03.23.2006, 01:37 PM
Hallo boys who of you thinks necessary for not to make slip the pinion, cut the shaft of Feigao\bk\lehner motor?
Name:	DSC01156 (Small).JPG
pcnutz
pcnutz's Avatar
03.23.2006, 02:47 PM
I cuss hard and live at people that cut thier shafts, I use loctite on the shaft and put the pinion on, you do not even need the grub screw. Just need a pinion puller if you ever want to take it off
virusss
virusss's Avatar
03.23.2006, 02:52 PM
I dont like a loctite prefer a grub screw.I dont have the pinion puller :)
pcnutz
pcnutz's Avatar
03.23.2006, 02:53 PM
your loss I think picking up a 10$ pinion puller is worth it for striength of shaft
virusss
virusss's Avatar
03.23.2006, 02:56 PM
sure, you have reason, but the grub screw is more comfortable :)
where I can buy a pinion puller ?
coolhandcountry
coolhandcountry's Avatar
03.23.2006, 03:05 PM
I put a small flat spot on the shaft. It takes very little away from strength. it makes it makes it tougher for pinnion to spin around on shaft.
Dafni
Dafni's Avatar
03.23.2006, 03:07 PM
I always do it like you, viruss. Grind a flatspot into the shaft, and crank the pinion setscrew as hard as possible. I don't even put threadlock on the setscrew.
Let me see your hands in the air, boys, if you do the same!
Be carefull when you grind the shaft! Don't let the metal shavings enter the motor! Cover it up.
virusss
virusss's Avatar
Thanks cool, also I make a small flat spot on the shaft...
Yes Dafni, I cover always the motor before cutting ...
Today i put in my buggy a Bk 13L whit 6S lipo...
This motor seems very powerful, not less than 1940/8....
Dafni
Dafni's Avatar
03.23.2006, 03:18 PM
Good lad, Virusss! When I'm in Italy next time, I'll send you a PM and we should go for a bash!
3 simple reasons why I don't like the "smear threadlock on the shaft" method:
-it's a mess, really
-needs time to dry, so no quick changes on the track
-if you don't get decent threadlock, the heat from the motor can melt it loose
-if you DO get decent threadlock, it will be hard to pull it off, even with a puller
-pulling hard on pinions puts unneccesairy axial force on the magnet/shaft connection
oops, already 5 reasons :005:
Throw you hands in da air for setscrews :cool:
virusss
virusss's Avatar
03.23.2006, 03:24 PM
:) yes all true...
Nice Dafni you come to Rome I accommodate you and I make you to visit the city..
pcnutz
pcnutz's Avatar
03.23.2006, 04:22 PM
I am not going to argue, but just to let other know if they come up with the same questions
mess can be cleaned quick with scotch bright
dry time is 24hrs if your changing pinions at track your screwed in first place
cheap decent thread lock all works
if you heat your motor to melt threadlock you done screwed up your motor 400 farehight
pinion puller will pull anything off your shaft without out screwing up rotors glued to shaft
pinion puller put absolutly no pressure on rotor magnets only on tip of shat and pinion
Dafni
Dafni's Avatar
03.23.2006, 05:08 PM
Oh okay. I didn't knew those pullers only push on the shaft.
Thank you
DAF
coolhandcountry
03.23.2006, 06:15 PM
I had the same worries dafni. I didn't like the idea of pulling against the magnet. It is nice to push on the end of the shaft for sure over pulling on magnet. I guess it is only one way to find out how it works. I have to try it one time and see how it goes.
Rtsbasic
RC-Monster England!
Rtsbasic's Avatar
03.23.2006, 06:26 PM
I just get a dremel to the shaft as well, after using threadlock to hold pinions on in my Mini-T its not something I want to do again :)
  Send a message via Yahoo to Rtsbasic
pcnutz
pcnutz's Avatar
03.23.2006, 07:09 PM
rtsbasic do you own a gws micro pinion puller?
