BL 380C-6L Maxx-Pede Pics, Need Alum Diff!
Rusty4Ever
RC-Monster Not Stock
Rusty4Ever's Avatar
BL 380C-6L Maxx-Pede Pics, Need Alum Diff! - 03.27.2006, 10:02 PM
Custom built low dropout 6v BEC for the servo/RX in the clear shrink. The homemade KAN 350mah (charges to 500mah) pack powers the 5v to the Warrior BL ESC (so no cogging), cooled by ball-bearing PC fan running from main batt, not that it needs cooling yet. That power switch is double throw, it cuts the ESC plus the servo/RX circuits. Zip-tie holding batt... will fix that.
Speaking of the batt, I built these two 7cell packs (charge to 3800mah), 12ga Deans wet noodle wire, Novak bars, these cells have higher avg voltage than IB3800's & better power (IB more runtime). They barely hit 45C while running; these cells will hurt a Pede.
Four 1.125" holes drilled for batt cooling, & the new Swami wheelie bar. I dremeled stock chassis, 7cell sXs fits great.
Really fun while it lasted, before the trans blew. About 3mins. Rolling wheelies on command, a real beast. Definately in Maxx class. Wheelie bar is mandatory...
How to keep it running?? It's so much fun. The nitro 4-tec steel rear axles work great & are holding up. The metal planetary (spider) gears inside the diff gear stripped bigtime, they are made with soft metal. Robinson Racing no longer makes the hardened ones. And Cold Fusion Racing no longer makes the aluminum diff gear housing (that I know of, it shows on here as Out of Stock), so stock plastic is all there is. 10 year old model, so this is end of the road I guess??
Accelation was awesome, as was the wheelie action. But the spider gears stripped while braking (I pulse the brake, Hitec SRX lacks ABS) from about medium speed (30mph), the wheels locked on pavement & I heard a crack. I have a Futaba 2PL AM with ABS... maybe I should use it.
Anyone running a spool? Locking the diff action (spider gears) with glue/ca/epoxy. Maybe JB weld would be strong enough if it doesn't eat the plastic gear. But I think that would put all the stress on the diff gear teeth. I won't run smaller wheels, it feels just as a T-Maxx, minus the noise.
Aside from staying off pavement/TX Expo/looser slipper/higher pinion/spool locked diff ideas, does anyone use another idea? It's a little fast for the front yard, so I'm forced to use some pavement and slow the thing down.
maxxdude1234
maxxdude1234's Avatar
03.28.2006, 05:00 AM
AT LAST!!! I've found someone who uses Elite 3600 cells!! Been looking for someone to give an opinion before I shell out a load of money to get a set. Do they perform as wells as CBP says? And are they much bigger than GP3300, because looking at the specs they're quite a bit longer? It's already a bit of a tight fit with the GP's.
Oh, and nice truck rusty!
Rusty4Ever
Rusty4Ever's Avatar
03.28.2006, 09:37 AM
Thanks, & yes the cells are just a tad larger than sub-c but all 7 fit easily in the Pede with very minor dremeling (2mins worth). I used a cheap $8 jig (really only 5 fit at once or it would distort) & when I had em soldered straight, CA'ed them.
They DO perform as good as CBP says. Probably why they're outta stock. Glad I got mine now. No heat (it's really unbelievable) and more power than you could ever want. 3800mah shows on the ICE charger too. Makes my GP3300 seem like a AAA pack.
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
03.28.2006, 06:37 AM
Rusty with a pede? hmmmmm lol.
  Send a message via AIM to nbcaznmaster
Rusty4Ever
Rusty4Ever's Avatar
03.28.2006, 09:46 AM
lol... My "handle" is rather old... The Rustler was my first R/C and I actually raced it quite well... but that crowd is way younger than me in many ways. So when I got my T-maxx and enjoyed it alot, I converted the Rustler to Pede for "quiet" bashing around the house instead of going to park.
easy
03.28.2006, 08:30 AM
I run the 380C-6L in a pede, I packed the diff with heavy automotive grease, after heavy and hard running have yet to do any damage to the planetary gears or tranny, I am running the alum and steel diff. While not breaking the tranny I have broken just about evrything else chassis, wheels,arms, this is a very fun little motor.
Rusty4Ever
Rusty4Ever's Avatar
03.28.2006, 09:38 AM
That sounds like a great idea to lessen the diff action for the spider gears, & the motor does rock, but you have the CFR steel diff...
If I can't get one now, I'm basically up the creek right?
coolhandcountry
coolhandcountry's Avatar
03.28.2006, 03:50 PM
How does the maxx tires do on your pede? I am getting ready to put one together and wanted to know on the tires.
Peace!
Country
Help support the
Rc-Monster
Buy here
Rusty4Ever
Rusty4Ever's Avatar
03.28.2006, 05:29 PM
Had a breakthru today...
Took the trans apart... basically my fault. I had let the carbide slipper balls go. So it was like a step function, either go or no go. During braking on pavement, a planetary gear fractured as the Maxx tires skid across the road, causing a bind, causing half the diff teeth to rip off.
Luckily I had a spare plastic diff gear. I brake cleaned the old sun/planet gears/shafts (even the broken one) and put them in the new diff case. Then filled it with 5min Plastic Weld. In about 3mins I had a perfect locker.
Re-installed slipper with new carbide balls and set correctly, now the BK7020 brakes very smoothly on the pavement instead of ripping the Maxx rubber across it (my fault). Slipper sounds a bit narly, & heats a tad, but I was ripping up the street today thru a full 3800 pack. Sweet!
Anyone who wants to make a MaxxPede I recommend leaving the stock drivetrain. The plastic needs to give. Forget CVD & for now the plastic output yokes holding fine. Just the alum idler & 4mm 4-tec metal rear axle. The locked diff was my choice, turning radius is unaffected, but slipper setting is crucial to keep the diff gear alive. The plastic teeth can take enough horsepower to get out of anything plus the locked diff gives more traction to the 2WD truck.
The stock slipper is the exact same as on the Maxx... anyone can point me to a better one? Thanks!
Serum
Serum's Avatar
03.28.2006, 04:52 PM
His maxx tires are currently ruining diffs Leroy.. :p
those large tires put quite some stress on it.
squeeforever
squeeforever's Avatar
03.28.2006, 06:56 PM
i've been wondering if the strobe setup would work? i have never seen one on a pede or rusty but if its the same as a maxx i dont see why it wouldnt work...
Rusty4Ever
Rusty4Ever's Avatar
03.28.2006, 07:27 PM
Slippers are the same right down to the stupid pegs.
But doesn't the Strobe bolt to a 51T Ofna gear? Using a 84T spur now... few more teeth. Even if I did work out the gear ratio, is Ofna's pitch 48 or something else? Even then it's outta stock; I guess it might come back right? (don't want to sound neg on here but the CFR Rustler/Pede alum diff gear is listed here outta stock, but it's really gone for good for well over a year now)
boss 302
03.28.2006, 08:07 PM
strobe slippers are mod1 pitch
MetalMan
MetalMan's Avatar
03.28.2006, 08:10 PM
You know, you could get some 1/8" steel differential balls instead of the pegs. They last a lot longer, are more consistant, and are cheaper.
http://www2.towerhobbies.com/cgi-bin...?&I=LX2760&P=7
These work with Kimbrough and HPI spur gears that are a direct fit to the Rustler/'Pede.
The Strobe slipper wouldn't be ideal IMO. A 51t mod1 gear won't even fit onto the Rustler/'Pede transmission. The largest I have used was a 46/49t mod1 gear (don't remember the exact tooth count). Besides that, it would be difficult to get the right gear ratio.
Rusty4Ever
Rusty4Ever's Avatar
03.28.2006, 08:24 PM
I figured they'd use heavy duty, expensive pinions. But doesn't Robinson Racing or someone make a better slipper than stock for the Maxx, since it should fit the other Traxxas vehicles.
MetalMan - check 4 posts higher - been using the the Carbide balls for years now & never use Traxxas spurs on the Rusty/Pede. That was the point of my post above, they had worn flat spots causing the slipper not to work, thus eating my metal planetary/plastic diff gears when I applied the brakes. So I put new in carbide today, locked the broken diff, & all is well.
edit: Robinson Racing Double Disc slipper seems like an option. The kit comes with a 72T spur, but they make a 78T for it, close enough if it'll fit & if it's actually better than carbide balls, anyone know if it's better?
