Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
CC Blower....Blows
georgec
georgec's Avatar
CC Blower....Blows - 05.09.2010, 10:15 AM
Thought I would give a quick review of the new CC Blower, all I can say is it does just that..BLOWS! After just three heats and the A main there wasn't a single blade remaining on the fan! Good idea but it will not hold up to the demands of 1/8th off road racing and yes there are several large chassis slapping jumps on the track that I race at, as all good 1/8th tracks do. Definitely not worth the money or the time it takes to install it.
nitrostarter
nitrostarter's Avatar
05.09.2010, 08:45 PM
Not doubting what happened to yours, but about 90% of our 1/8th drivers have them and never complained once about them.
Sorry for your bad luck with it.
N. Rustler conversion
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
05.10.2010, 02:46 AM
must be like one of them new blade less fan designs they had them for sale at a local shop for moving air about the house, just a centrifugal fan in the base and a big ring on top in which air came out of the perimeter. they suc....err...blew as well. what a pathetic idea THAT was
  Send a message via MSN to shaunjohnson
georgec
georgec's Avatar
05.10.2010, 09:22 AM
I'm not giving up on the idea, just the bushing motor that Castle chose to use for reasons of cost I am sure. Found some 30x30x7mm "ball bearing" fans online for about 8 bucks shipped, so I bought two one to go in the CC Blows and one for my MMM that I discovered after tear down and clean up that the fan no longer works on it...go figure! I will just have to reuse the wires off the other two, no big deal there. Like I said, it's a good concept just a cheap fan. Even with one blade missing after the first heat my motor came back about 20deg. cooler than it normally runs, normally it's 155deg. with the fan 135deg.
Jahay
05.12.2010, 05:55 AM
if you change the fan on your MMM could you do a write up with pics??? Something i would be looking into doing but not sure what parts to buy etc....
I was also looking into the blower, but after seeing pics of it being quite cheap looking, i was a little hesitant... I may still consider one...
Thanks
Josh
georgec
georgec's Avatar
05.12.2010, 06:18 AM
Thanks
Josh
The new ball bearing fans should be in this week. The only thing I will have to do is rob the wires from the old units and install them on the new fans except on the cc blows, instead of gluing the fan in the shroud I will use four M3 screws and nylock nuts to hold the new fan in. I'll take a couple of pics and post them up.
Jahay
05.12.2010, 07:25 AM
thanks a lot! Something i will def look into !
georgec
georgec's Avatar
05.13.2010, 08:31 PM
Well Josh the new fans showed up yesterday and they are a perfect fit in the MMM and CC Blows. As you wanted I will post a few pics as I go through the swap over, but first I want to explain why I do the wiring like I do. To begin I don't try and desolider and resolider the wires to the PC board on the back of the motor because the solider points are tiny, very close together and recessed in the plastic motor case. To me it's just not worth the risk of all the things that could go wrong like over heating the PC board or overlapping solider joints and on and on, so this is how we do it.
Here's what you get for the money
You will notice that the new fan comes with three wires, red, black and yellow. The yellow wire is not needed so cut it off as short as you can then cut the red and black wires leaving them long enough to work with.
Cut the wire to be reused off the old fan in about the same place that you cut the wire from the new one, this way the wire after joined will be about the same as the original. Then strip the insulation back on the ends to be joined about 1/8" apply flux paste to the bare wires and pretin with a small amount of solider, cut two pieces of heat shrink tubing 3/8" long and slide it over the wires back far enough that the heat won't get to it when you solider the wires together. Allot of people use the helping hands jig to solider wires together, I prefer a 1/4" thick piece of ceramic tile and a small lite weight clamp, a cloths pin will do. Now clamp the fan to the tile and solider the wires together, then slide the shrink tubing over the joint and shrink it with a heat gun or lighter. Slap that sucker back in the case, plug it up and you are good to go.
There are several differences that I noticed between the ball bearing and the old bushing fans, first off the motor is larger on the bearing unit therefore the blades are a little shorter and beefier, that's a plus also there is no up and down play on the ball bearing fan like there is on the bushing fan. Not sure what the CFM is but I can tell that the new fans are moving more air.
A side note on the CC Blows, when they made the fan shroud that fits over the motor they didn't allow any place for the air to exit after the fan pulls it in! So I cut away 5/8" between the two zip tie tracks leaving about 5/32" between the shroud and the motor. That way the air can exit almost as fast as it enters, taking the heat with it! Witch after all is the purpose of the blower....isn't it?
Hope this is of some help
GeorgeC
armourbl
06.23.2010, 12:37 PM
George, where did you order the fans from? Need to pick up a few.
My cc blower fan lost one blade in the first night of running. Like the blower, hate the fan. Already lost two fans in my ESCs too. Need a reliable replacement.
ben
georgec
georgec's Avatar
06.23.2010, 12:45 PM
I bought mine "HERE"
armourbl
06.23.2010, 12:50 PM
Awesome, just order 4. Thanks for the research, post and info.
ben
Shonen
Shonen's Avatar
06.29.2010, 04:12 PM
GeorgeC
The airflow is supposed to go between the fins on the motor can. When I first got my blower I was confused about that as well but after taking it out for a run it made sense. The shrouding is there for a reason, it directs the airflow around the motor for more even cooling. It's true that squeezing that air through that small space will drop the CFM's significantly, but I'm sure Castle did their homework with this. High airflow is useless if it isn't put to work.
It does feels a bit cheaper than I'm used to for a Castle product (very stiff plastic and wires), but it does the job. I haven't had any problems with it yet, although if/when the fan dies you've shown people a replacement option
georgec
georgec's Avatar
06.29.2010, 04:39 PM
What????...How can there even be "HIGH AIR FLOW" when it's being packed up in a box and forced back through the top of the fan? With over whelming back pressure there is no air flow and therefore no heat exchange!
Shonen
Shonen's Avatar
06.29.2010, 05:01 PM
by cutting up the shroud you decrease backpressure and thus increase CFM, but because the shroud isn't directing the air around the motor, you can't cool the motor as effectively. the air is supposed to flow around the motor, between the shroud and the motor fins. If you wanted maximum airflow, you would just ziptie the fan to the top of the motor without a shroud.
What you're effectively saying in PC terms is that instead of having system/cpu fans inside the case, it's much better to take out the fans and instead put the entire case in front of a fan moving huge amounts of air. Sure, backpressure will drop CFM's but what's the point if what CFM's you have are not being used effectively?
scarletboa
scarletboa's Avatar
06.23.2010, 03:30 PM
damn, out of stock. i have a MMM that needs a fan and my castle blower broke a fan blade within 5 minutes of light bashing.
