Instead of a Pinion, Use a clutch bell? and double check my gearing please.
Jahay
Instead of a Pinion, Use a clutch bell? and double check my gearing please. - 07.16.2010, 05:41 AM
Hi Everyone!
Firstly... Thanks to simplechamp for delivering me this awesome ofna centre diff!
I am quite shocked by how amazing the build quality is!
Question 1
Anyway, as i decided against the slipperential and because i am converting my savage flux to a CD rather than a tranny which has a slipper... I feel i may need some sort of give in the drive line....
I saw somewhere but i cant remember, someone using a clutch bell and pads to protect the motor. Basically a nitro setup...
Is this easy enough to do? Would it be possible for my 1520? And is it necessary taking into considering the weight etc of my ext savage?
Question 2
I just want you guys to check that my gearing is correct before i buy the wrong pinions. I am just a little confused as it looks ill be using 9t-11t pinion to get my desired speeds... Smaller than i have ever used (never had a centrediff)
Does this look correct? These are the speeds that i am running now with my current 18/47 gearing, and with no heating issues etc... so i am looking to maintain these speeds with the centre diff....
Thank you
07.16.2010, 06:59 AM
1.- Tekno RC makes a clutch adapter to use standard clutches on electric motors. This would give you an area for stress relief, but also adds maintainence to your vehicle because of worn out clutch shoes and bearings. Another factor to consider is that the clutch systemadds the width of the clutchbell to the overall length of your motor/gear combo.
It is a viable option, but not one I would choose.
2.- That gearing is correct. A transmission offers the gear reduction you need for a good spur/pinion combo, but adds a weakpoint. A CD eliminates the weak point, but doesn't have the gear reduction necessary for an ideal spur/pinion combo. But it will work!!
Jahay
07.16.2010, 07:04 AM
Thank you for the fast response...
1. How strong are these motors are taking abuse? i have basically been running my savage with the slipper tightened all the way so far... Should the motor be fine? As long as i dont land and big jumps on power then nothing should really go wrong correct??? I dont mind my weak point being my pinion as it is easy enough to change, i just dont want to be replacing my f/r diffs and CD spur.
2. i guess having a very small pinion means it will wear very fast... at least that will wear and hopefully wont wear out my spur too quickly...
I was looking at the Novak Pinions, hopefully they should be all gd
07.16.2010, 07:16 AM
The motors are quite strong and take abuse well. Not landing on throttle (driving sensibly) will keep your motor running for a long time. Have fun!
Jahay
07.16.2010, 08:11 AM
thats all i needed to hear. Thanks a lot!
thzero
07.16.2010, 11:04 AM
Pictures and info!!
Hi Everyone!
Jahay
07.16.2010, 11:06 AM
on what??? my conversion??? once i start installing everything, pics will be taken and posted in my thread.
thzero
07.16.2010, 11:50 AM
On the ofna center diff that simplechamp did for you!
simplechamp
simplechamp's Avatar
07.17.2010, 01:57 AM
It's nothing I did to customize it, I just sold him an Ofna 8-spyder diff.
Jahay
07.16.2010, 12:00 PM
will get pics up tonight.
Finnster
KillaHurtz
Finnster's Avatar
07.16.2010, 04:54 PM
I don't know if you can use a CB with Mikes CD mount. The adapter plus CB will extend the gear face out quite a bit. You maybe able to reverse the CD so that the spur is opposite of the motor, but IDK.
Tekno always used set back motor mount to acct for the length
07.17.2010, 12:37 AM
Harold always used rubber donut sex spacers to acct for the length
I fixed that for ya, Finn.
Finnster
KillaHurtz
Finnster's Avatar
07.17.2010, 11:41 AM
Well you've gotten modest. Linc said you always liked the full length colonoscopy
nuz69
nuz69's Avatar
07.19.2010, 07:32 AM
Hello,
Just to say that clutch bell setup will increase the distance between front bearing and mesh contact, resulting in a lot of stress on the front bearing !!! And that is BAD for efficiency and bearing ;) Forget it... Contact some pinions suppliers and buy them by quantity of 20
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
07.17.2010, 01:48 AM
When Fisting or...? Haha
Tip: Always use spellcheck....
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
