Mamba max update fail
uarghhh
Mamba max update fail - 07.20.2010, 04:24 PM
Hi guys. I update my mamba max to the new firmware version this morning and somethig happend so the update could not finish (an error message from castle link program) So now i have a non working esc.... only steer left and right if battery connect, nothing else is working and computer act like nothing plug in.... it happen to someone else?
Tnx
Julien
Pdelcast
Pdelcast's Avatar
07.20.2010, 04:47 PM
Tnx
Julien
Try forcing an update. This version of software doesn't change the bootloader, so it should still connect correctly with the Link.
Patrick del Castillo
President, Principle Engineer
uarghhh
07.20.2010, 04:55 PM
how do I do that? the connection status is red.... and when I plug it, the computer see nothing....
Pdelcast
Pdelcast's Avatar
07.20.2010, 06:45 PM
Just heard there is a problem with this release and the original Mamba Max (with the USB port on-board.)
We are pulling the release until we fix this problem.
You can still update the Mamba Max with a Castle Link, but there was an issue with the USB driver on the Mamba Max.
uarghhh
07.20.2010, 07:27 PM
ok! I have the mamba max with the USB port on-board... problem found! Keep me in touch with the news please! thnx for the info!
Julien
Dadx2mj
Dadx2mj's Avatar
07.20.2010, 10:11 PM
Wish I would have read this an hour earlier. My son just updated his Castle Link and plugged in his Mamba Max through the USB port. He now has a totally dead Mamba Max. Any way of fixing this?
Blindman Racing
Powered by Mamba 5700
Thomas Porfert
Thomas Porfert's Avatar
07.20.2010, 10:21 PM
The only way to fix it as this time is to use the Castle Link adapter and hook it up to the Mamba Max via the receiver wire. If you do not have a Castle Link adapter, please give us a call in tech support or throw up a post here, we'll get you setup with a fix.
Our engineers are working on a solution at this time, but it does not appear the controllers that have been updated will work with the side USB port until they are updated via the receiver wire and the adapter chip. If you do have an adapter chip, your updated Mamba Max will connect just fine. Let me know if you have any questions or concerns.
Thomas Porfert
Castle Tech Support
Dadx2mj
Dadx2mj's Avatar
07.20.2010, 10:32 PM
Thanks Thomas you saved us AGAIN!!!. Plugged in Castle Link through the chip rather than the USB port and finished the update. The Mamba lives again
Blindman Racing
uarghhh
07.20.2010, 10:54 PM
hi thomas... I do not have one, what can I do? Do I need to buy one?
Julien
crazyjr
crazyjr's Avatar
07.21.2010, 07:29 PM
Well that's great!! I lost mine in the move a couple years ago. I did mine today and it no longer recognizes on the computer, $%^*!!!!!
To top it all off, I can neither afford to send it in or buy the castle link right now, so i'm officially out of rc for now
kazuaki
07.21.2010, 09:09 PM
If you PM me your shipping info, I'll send a Castle Link to you first thing in the morning, free of charge
crazyjr
crazyjr's Avatar
07.21.2010, 10:44 PM
Thanks sir, but the less i run my T4, the less it breaks. I'll just wait till i can get a program card or get a MMpro
brushlessboy16
brushlessboy16's Avatar
07.21.2010, 09:30 PM
I just bricked my mamba monster -.-
bdebde
That's All Folks!
bdebde's Avatar
07.21.2010, 09:33 PM
Do you guys not know what BETA means? It means not finished, may have bugs, use at your own risk! If you can't do without your ESC, don't use beta software on it!
crazyjr
crazyjr's Avatar
07.21.2010, 10:43 PM
Sorry dude, I was ticked off at the time. I knew the risks, should have read the four pages before DL'ing, lesson learned. I had to do a major reboot to my computer and just DL'ed it not knowing about the updates.
Now then, will the castle program card work to reboot the mamba? I know it can be used as a link to the computer as does the castle link. Been meaning to get one and now is a good reason as any
