Mid motor Rustler VXL
Candyman2
Candyman2's Avatar
Mid motor Rustler VXL - 07.25.2010, 05:51 AM
I have been meaning to do this for a while, since moving to lipo, the 3s I have is very powerful and not very heavy (I was running 9cell NIMH). This has upset the ballance a bit and turned it into a complete wheelie machine. In order to combat this I have spent a total of 6 hours and an old chassis, I didnt want to butcher my good one, turning the transmission around.
The aluminium gearbox case, like many of them, can have the wishbone/arm pickup points fitted to either side. This is essential to keep the toe in and anti-squat/caster on the rear arms.
had to trim a few places here to get the gearbox to sit flat in the chassis
with the rear of the chassis cut away it was very flexible, this brace screws to the chassis and the back of the gearbox, then the gearbox to the chassis again. The result is actually stiffer than the stock setup.
Rear brace for the shock tower and wheelie bar. The black plastic im using is delrin, a tough nylon.
made to measure for my Rhino 3s 4000mah pack from hobbycrown :D
all together
Candyman2
Candyman2's Avatar
07.25.2010, 05:52 AM
had to make another piece to attach to the rear brace and then to the bottom of the wheelie bar
brian015
brian015's Avatar
07.25.2010, 06:58 AM
Looks nice. I did something similar a while ago by making my own aluminum chassis and I was amazed how well the rustler handled (all 4 wheels on the ground!). Your delrin rear shock/wheelie bar brace looks very solid - nice work. Some people who have done this have not taken the time to get that shock tower mounted solidly.
07.25.2010, 09:09 AM
Indeed, seen it done a few times, but this is definately the best thought out & executed concept by far
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.25.2010, 09:53 AM
Very nice job C-Man2 !
If it was for the Shiny Aluminum it would look 100% factory.
snellemin
2 KiloWatt RACER
snellemin's Avatar
07.25.2010, 02:39 PM
Nice work man. I see that a lot of thought went into this project.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
07.25.2010, 02:41 PM
Very clean job, nice! So, essentially what you have now is an e-Jato?
Candyman2
Candyman2's Avatar
07.25.2010, 02:48 PM
lol, thanks chaps.
just had a test run, quite happy! :)
http://www.youtube.com/watch?v=LMdRMRgNWj8
Galladon
07.26.2010, 01:25 PM
Looks great! And judging from the vid, it handles a lot better than stock.
And just to nitpick:
Nylon is PA, polyamide, while Delrin is a brand name for POM, or polyacetal.
Candyman2
Candyman2's Avatar
07.26.2010, 01:39 PM
Well I didnt know that! thanks
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
07.26.2010, 01:27 PM
that's the nicest mid-motor conversion i've seen yet...awsome work!! WOW
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
07.26.2010, 05:49 PM
well done. It definitely seems to keep the front tires down a bit more than stock for sure
crazyjr
crazyjr's Avatar
07.28.2010, 11:27 PM
Part of that is the physics of the motor, it's running in reverse to the normal direction. In normal (rear position) the rotation of the rotor is torquing the motor can and tranny down, causing wheelies. The same thing is happening when you tap the brakes or goose the throttle to adjust for a landing in mid-air. In candymans setup the motor can and tranny is twisting down as well, But due to reversed wires and position the torque is pushing down on the front, not the rear. This is the reason why the X-factory X-6/60 cars have a 4 gear transmission, to bring back the proper rotation to control jumps and help plant the rear for max traction
nitropyro
07.26.2010, 10:44 PM
nice work!!
Danny
Candyman2
Candyman2's Avatar
07.29.2010, 04:08 AM
forget it
