Taming the dreaded 10s spark -
01.04.2011, 06:01 PM
As some of you large scale guys may know, you get one heck of a spark when you plug in an 8-12s setup. And Castle escs do not like slow charge up, so i thought why not put one of these http://www.robotmarketplace.com/prod...-SWHELLA2.html between the batteries and the esc so that you can plug your packs in and then flip the switch to let all of the voltage flow through the already connected wires to avoid the spark. Am i right on this? I mean the spark is from the caps charging up; correct?
01.04.2011, 06:24 PM
Its going to spark no matter what. You are just moving the location of the spark to the inside of a switch rather than the battery connector. As far as i know the spark is harmless.
Soldermaster Extraordinaire
01.04.2011, 06:45 PM
Triac switch.....
01.04.2011, 08:08 PM
Originally Posted by What's_nitro?
Triac switch.....
TRIAC stands for "Triode for Alternating Current", so can it even be used to switch a DC load?
01.04.2011, 08:16 PM
I hate to say it but, I love the spark! There is just something absolutely wicked about the sound and look of all that power! Watch some newbies eyes bulge out when you connect and enjoy an evil chuckle.
01.04.2011, 11:17 PM
I am there with ya on that one. I went to the local flying club and watched this guy connect the plugs on his Trex 700 and boy what a show. Love it. I use extra caps on all my ESCs and get a decent spar too. Just change the connectors more often. No big deal, and keeping connectors fresh means lower resistance.
01.04.2011, 08:34 PM
Of course it can!
It's just two SCRs connected inversely so it can conduct current in both directions. You could just use one SCR, but a Triac would allow for regenerative braking.
01.04.2011, 08:18 PM
A easy fix is to move up to 12s setup. Then the 10s spark wont seem so bad. haha
01.04.2011, 08:41 PM
Seriously would it still spark just as bad if you had a switch turned to off when you connect the batts? The spark is completely harmless, it can seriously pit the connectors. Due to my limited hand strength, i usually need someone to connect them for me, which is difficult when there scared  .
01.04.2011, 08:57 PM
Yes, the spark is still there because no matter if the ESC is on or off, the caps are the parts that cause it.
01.05.2011, 02:44 PM
What i was getting at though is that the switch i had linked would be installed between the batteries and the esc switched to off essentially isolateing the batteries from the caps until everything is connected then turn it on. I dont care if a spark occurs inside the switch as long as i doesnt happen when i plug the batts in.
01.04.2011, 08:52 PM
A triac has a ~0.7v drop so the power dissipated at ~20A would be 14w - not a small amount. Also, you would need quite a large triac to handle the 150A+ bursts without damage. If anything, a smaller triac could be used to get the caps charged up, then connect the main wires together (bypassing the triac) for running.
If you still want to go this route, I'd use a small bank of FETs to do the switching. That way, you can keep it in the circuit with minimal losses if you really want to use it while running.
01.04.2011, 10:20 PM
Hey I didn't say it was practical...
01.04.2011, 09:02 PM
Basically the spark would just be transferred from the connectors to the switch contacts, and they would still get pitted after awhile.
01.04.2011, 09:04 PM
Maybe use a parallel set of "sacrificial" contacts? Something easier and cheaper to replace?
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
