Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
Too much slip
jamesban
Too much slip - 08.12.2011, 09:06 PM
my setup is a 40 x 82 mm 2000kv motor, 4 cell A123 batteries and 14T pinion in a Muggy. I lightly scuffed the slipper pads. I made sure none of it got anywhere on the slipper when I lightly greased the threads on the adjustment ring. I have it tightened all the way down and it still slips so much the truck will not barely move. Is something wrong ? or do I just need another spring maybe in this heavy truck with a 2000kv motor?
http://www.youtube.com/watch?v=VnQ06skycxU
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
08.12.2011, 10:10 PM
It shouldn't be slipping much at all when it's tightened down.
I'll ask a silly, but relevant, question: Were there any parts left when you finished assembling the unit?
Can you take a side-on picture showing how the parts are arranged, just to confirm the unit is assembled correctly?
I believe the axial relationship of the springs can affect how much pressure they apply. They have to be lined up with each other a certain way.
jamesban
08.12.2011, 10:23 PM
I will take it out next week and post some pics. I did not have any extra parts.
jamesban
08.14.2011, 08:47 PM
Tried two different camera and every picture is blurry. I will take it apart tomorrow and post pics of the components laid out in order they are installed. Im pretty sure I have it right per the instructions. Im hoping something is wrong though so i can get it working.
http://s9.photobucket.com/albums/a10...slipperential/
molak
08.14.2011, 08:50 PM
Try a different photographer
pinkpanda3310
pinkpanda3310's Avatar
08.14.2011, 09:52 PM
Did you scuff the pressure plates with sand paper?
What's_nitro?
08.14.2011, 09:49 PM
Yeah I can't tell anything from those pictures...
I thought of something you can check- Make sure the side of the spur gear with the fiberglass friction pad inserts is facing the large end-cap of the diff. The flat side of the spur gear should face the large thrust bearing toward the small end-cap of the diff. If the friction pads are facing the wrong way it will cause the behavior you are seeing. Other than that I don't know...
cmac
cmac's Avatar
08.22.2011, 08:36 PM
What weight diff oil are you using? From what I can tell that's how I put mine together. I have not had a chance to run my truck because I'm still waiting on parts.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
08.22.2011, 09:19 PM
In the video you mentioned that you tightened it as much as possible, but the springs were not completely compressed, indicating that the perhaps the threads were not greased adequately. You should be able to completely flatten the springs without excessive effort – especially when out of the truck.
jamesban
08.23.2011, 08:49 AM
It was greased well and tightened easily, it is tightened so that the springs are almost perfectly flat. The ring is so tight there are only threads on the bottom half of the ring. There is absolutely no way to tighten it any mroe than it is now so if thats the only solution this will not work for me at all.
RC-Monster Mike
Site Owner
08.22.2011, 09:21 PM
Also, you did mention the grease in the video - you are using the AE grease to grease the threads on the diff cup/adjustment ring, correct? You do have a large, heavy truck, so I expect the need for a tight setting, but you should be able to make full adjustment if the threads are greased well(meaning you should be able to completely flatten the springs against the slipper assembly).
What's_nitro?
08.22.2011, 11:35 PM
Is it possible the diff body isn't threaded far enough to allow full travel of the tightening ring?
jamesban
08.23.2011, 08:51 AM
It could be a possibility.
RC-Monster Mike
Site Owner
08.23.2011, 10:01 AM
only possible if the slipper side(large) endcap isn't completely tightened flat to the diff cup(this would also result in a leaky diff of course). Everything is sized to allow assembly with minimal spring tension and also allow full tension when tightened - the nut will partially disengage the threads when fully tightened, but will not thread itself completely off the threaded portion of the cup.
pinkpanda3310
08.23.2011, 10:15 AM
Given it was designed for racers with lighter vehicles, your setup may just be a bit too much for the slipper, in which case add an extra wave spring. You shouldn't run out of thread then.
