Thread Tools Rating: Thread Rating: 160 votes, 5.00 average. Display Modes
Traxxas xo-1!
anunaki
Traxxas xo-1! - 01.21.2012, 02:44 PM
Now that the traxxas XO-1's are in peoples hands...bottom line I wanna race.I have a ofna lx1e steve neu 1521 2 extra winds and i live in miami fl and race 300ft or better and would like to start the first race for franklin and then all or bust 3 franklins oh yeah half a franklin lock out fee so if you dont show or considerably late you owe half a franklin show up make your adjustments line up cash out.1/8 scale or bigger is what i race.line up i dare you seriously.Plastic melter
anunaki
02.05.2012, 12:35 PM
OHHHS SHATT GUYS guess what ive beaten 3 not 2 but 3 traxxas XO-1's.Fifst of all i told you that nothing traxxas builds is ment for 100+ period !! Now lets see why ive beaten them....the XO-1 is not stable Dude i told those pea brain people at my local hobby shop at the time i first glanced at the XO-1 it was junk they said "why you hating"?I said the thing is a parachute damit they said "No its designed by a computer to plant the chassis on the road" then these dummies showed me the video of the car in a glass case fully enclosed doing 100+ woww now i see why nic case told me speed runs are for geniuses.I SCREAMED the cars in an artificial enviorment as soon as the natural elements touch this car its over and soo started the bets,my ofna lx1e pro mod vs the hobby shop's owners XO-1.GUYS it wasnt even close no XO-1 EVEN finished the race spinning out parachuting in the wind i mean great god damm i even raced one while i was using 4s.Now the last one i raced the guys XO-1 slid soooo farrrr he burned a hole..
anunaki
02.05.2012, 12:48 PM
in his cars body look on you tube the car is basura so far the the traxxas XO-1's bought me a thunder power 65c pro race 5000 pack thanks traxxas! tip for all XO-1 owners spray teflon kevlar truck bed liner in the inside of the body it will stop so much flexing find it at any automotive store.total tally since XO-1's release ive made from racing 325 dollars,fasools,yen,euros,iras,puonds hahaaa.
Kirkinsb
Brushless All The Way!
Kirkinsb's Avatar
02.05.2012, 01:12 PM
I have a brushless RC8 buggy with a 1518 castle motor geared for about 70 and verified by GPS....but anyway...it is rock solid stable at 70mph. I can even throw it around back and forth at that speed swaying back and forth down my street.
It does not lift up and blow over...not even close...completely rock solid.
Now, I had a full bodied 1/8 scale LXE onroad car that would blow over at about 50mph if you nailed the gas. I sold it a week later because it was on its lid more than its wheels. Went back to my buggy and the stability it offers.
Something about the full body that acts like a parachute once a little bit of air gets under it. buggies just dont lift up and blow over like that.
I say the X0-1 owners should try to take the body off and all that crazy ground effects stuff that causes their cars to get airborn the second they go sideways off and find some type of buggy body. I bet the X0-1 owners will actually find more stability....with something other than a full body..... I could be wrong...would not be the first time...haha.
That is my experience with full bodies and such....my experience may not be what the masses have seen.
But something tells me the x0-1 would do better without the full body and flat bottom ground effects acting like a parachute.....All I know is my RC8 buggy has never even come close to blowing over at 70mph. And it is not even lowered!!!!
hey man you're cool!
anunaki
hey man you're cool! - 02.06.2012, 12:24 AM
Hey 100% i agree with every thing you said to the t. My ofna would blow back also just like you said but i took off the "high downforce wing"which was made for tracks i put in a tri level wing and removed two levels because the wing dosent need downforce at least for me but as you say with the ofna high downfoce wing at 65 mph it blows back ,we call it dancing which is bad for racing really bad! As for the buggy's body i use industrial velcro all around and i have vented fully the body for positive air flow and cooling .The guy i raced took the body off too....... spinnnn outt it also needs weight!!!
bruce750i
bruce750i's Avatar
02.06.2012, 01:26 AM
Congrats,
But we already knew that "pea brained" LHS workers don't know jack 95% of time. You said they never even finished a race.
Thirdgen89GTA
You can sleep in a car, but you can't race a house
Thirdgen89GTA's Avatar
02.06.2012, 12:27 PM
I wish I had read this thread in its entirety rather than just catching the post that got my attention.
So much mis-information!!!!
The Traxxas XO-1 is far more aerodynamic than your buggy Anunaki. It has a much lower Coefficient of Drag, which means it requires less power to reach the same speeds. It also will produce more downforce with less drag as well than a 1/8th scale buggy.
This is due to the fact that the body is fairly sealed, and the undertray will reduce the parachute effect most 1/10th and 1/8th GT bodies have because they don't have a tray. With a smooth body tray and the rear diffuser will cause the air under the car to decelerate when it hits the expanded section in the rear, again increasing rear downforce with a minimal increase in drag as compared to a full on wing. It takes advantage of the vacuum behind the car.
The full width front, canards, and splitter work together to reduce airflow under the body, and increase downforce on the front wheels. The splitter reduces underbody air flow, acting like an air dam. The side canards increase downforce, and work exactly like a wing does.
There is a NACA duct in the tray This is draws air from undertray over the motor for cooling.
How does all this compare with a 1/8th scale buggy? MUCH more efficient. Does a 1/8th scale buggy with wing produce more downforce? Yes. The massive rear wing creates alot of downforce, and its location aft of the rear wheels leverages that downforce on the rear wheels at much slower speeds. The further back the wing is mounted the more leverage it has. This much downforce is not needed for high speed runs. The wings are designed to produce usable downforce in the average speeds seen by buggies which is between 10 and 50mph depending on track size and layout. A 1/8th scale buggy much like an F1 car is CONSTANTLY accelerating. Buggies NEVER reach terminal speed on a track, most of them are far too short.
How about the partial body vs full body? Well the partial body is mostly sealed so the parachute affect is minimized, and the smaller area means that airflow has less area to act against if air gets under the car. However the partial body exposes the shock towers, wheels and suspension components directly to external air flow. This is a massive drag increase and creates tons of turbulence. 1/8th buggies due to their body design have little to NO downforce in front, in fact they have a fair bit of LIFT.
Another item to consider is the tire rotation, at 50mph the bottom of the tire where it contacts the ground is technically not moving at all relative to the chassis. However the TOP of the tire is moving TWICE as fast as the chassis. You don't wanna know what this does to the airflow. Massive turbulence. Look at the front wing of an F1 car, notice how the wing is designed to direct air up and OVER the tires? Thats to reduce the turbulence i just described.
_________________
Also, the X0-1's OFFICIAL top speed is 100mph, but in all likely hood based on some of the video's I've seen showing telemetry readings a fully charged pack will allow it to reach speeds in excess of 110mph. I wouldn't be surprised to find out its top speed is closer to 115mph.
  • 1989 Pontiac TransAm GTA, 5.7L LT1/M6 400rwhp+
    • Jammin X1 CRT Pro, MMM/1717, 6S
    • Hyper One Seven 1/7th scale GT car, MMM/1717, 6S
    • Hyper 10TT, MMP/1410, 3S
    • TL Mini 8ight, stock, 2S
  Send a message via AIM to Thirdgen89GTA
cmac
cmac's Avatar
02.05.2012, 03:58 PM
I believe that the engineers have done a good job with this on road car. The use the aerodynamics to help pull the car down to the road. Like a wing only in the opposite direction. The on road car that you had obviously did not have that benefit. They use some similar principles like the Indy cars. If you could invert an Indy car at speed it would hold the road because of this effect. I heard that these cars are a little unstable under 50 mph that is about when the ground effects start to kick in after that it sucks down to the road and is stable as can be. I have a Losi 8ight that will run just like your buggy and it too is stable at around 70 mph, I have not had it to 100mph, but I bet it would be a whole lot different. I'm sure it would not be as stable.
Kirkinsb
Kirkinsb's Avatar
02.05.2012, 05:03 PM
Such a cool car...I am so torn on getting one. I like to drive aggressive and my road that I drive on is probably not smooth enough for the XO. Oh well.
Thirdgen89GTA
02.05.2012, 09:17 PM
1/8th scale wings are like open wheel F1/Cart/Indy cars. They produce mad amounts of downforce at the expense of high drag from the wing.
A 1/8th scale buggy at 100mph if it still had its original wing will be supremely stable. But it'll require a ton of power to reach 100mph, more than the XO-1 needs due to the massive drag the wing will generate.
Almost all of my old nitro cars that topped out around 55mph would gain another 5-7mph without the rear wing. With the rear wing at those speeds there was massive understeer.
Now fab up a mount and stick a 1/8th wing on the FRONT of your buggy too and it'll stick like glue to the road.
anunaki
02.06.2012, 12:47 AM
#YOUTUBE TRAXXAS XO-1 they dont go down the street.and as for1/8th scale buggy needing alot of power listen the traxxas XO-1s gearing is 34 tooth mod 1 pinnion gear and 44 or 46 spur or what ever on 25c batteries unless you swap em out now Im geared 33/44 with 65c batteries i honestly get 3 passes then kaput capice.FACT when a rc BUGGY goes 70mph the force is 80 to 90 pounds of pressure on the wing look at it like this a midget stands on our rc wing and a elephant stands on a top fuel dragster.
josh9mille
josh9mille's Avatar
02.06.2012, 01:50 AM
FACT when a rc BUGGY goes 70mph the force is 80 to 90 pounds of pressure on the wing.
FACT: that is totally false. For one the wing mount would most likely break with 80 pounds on it. Second of all the bottom of the buggy would be dragging on the ground since there is no way those little shock springs are going to support 80 pounds. Take the wing and mount off of your buggy and hop in the back of a truck and hold that wing up in the air, have your friend drive at 70mph and then tell us if you still think there is 80 pounds of downforce.
anunaki
02.06.2012, 11:16 AM
[QUOTE=josh9mille
Listen dude i work on top fuel dragsters i refuse to argue with you but let me say this,can you name somthing that goes stupid fast that doesent have a wing?The degree/angle always determinates how much force the back wheels apply along with suspention or struts i.e "hookin upp".These brushless cars never hook up you could be at 80 mph and then..tire spin they skate the street the whole way unless you're a beast with throttle control then you wont smoke the tires.by the way what you wanna do wanna line up if the race is right ill fly you down here!
Not True
MiamiJato
Not True - 02.10.2012, 08:44 PM
Not true Cmac, I love my Losi 8 for that reason, it is completely stable at all speeds. I've had my losi 8 up to 113 MPH so smooth and stable it's not even funny. Just look at my videos. I have one pass at 106mph and it's a cadillac going down the street. So if you guys have any doughts about the stability of a buggy, i just proved it..
cmac
cmac's Avatar
02.13.2012, 03:58 PM
That's good to know that it is possible to maintain stability at that speed. I myself have never driven a rc vehicle at those kind of speed. If I can find the right kind of place I might give it a trying. What kind of gearing, motor,esc,tires etc did you use for that kind of speed?
