Fat Kid Engineering
Bondo's 6X6 Scale/Crawler recovery truck -
06.10.2012, 08:10 PM
Here's what I'm starting with, these are pictures the guy sent prior to making our deal. This thing had some serious issues when it finially showed up considering I was told other wise.
This is a RC4WD "Beast" 6x6
http://store.rc4wd.com/The-Beast-Bla...le_p_1175.html
During inspection I found;
5 broken off 2mm screws between 2 axle cases and over a dozen missing screws. The Mann body was broken in several places and all that was included was the floor pan and exterior shell, not sure if anything should have ben included such as door handles and hinges etc ? The servo mount was broken from crashing into something but it's reusable if I place a thin piece of alum over it and screw it into the Delrin. Also one of the front carriers is hogged out top and bottom from the missing kingpin bushings and someone just put a screw in and it worn the hole oval, real brainiac. And last but not least, the frame was bent in 4 places, no clue what they were doing with it ?
Once I received I was able to get a decent pic
Fat Kid Engineering
Fat Kid Engineering
06.10.2012, 08:12 PM
Next I tore down the 2spd tranny and found the idler gear pretty worn but with plenty left on it to last a while yet. I checked all bearings and bushings, cleaned everything and reapplied Mobil-1 Red Synthetic grease.
I then moved onto the original steering axle and drilled and tapped the broken
2mm screws and did a thorough cleaning and again used the Syn grease.
I bought 2 more steering axles from Rock @ RC4WD and tore them down as well and applied Syn grease during re-assembly.
http://store.rc4wd.com/Blackwell-X1-...le-_p_449.html
Fat Kid Engineering
06.10.2012, 08:29 PM
The running gear it showed up with is the stock 2 spd tranny, no shift servo, stock Outcry ESc with BEC brushed motor only but 4s capable. The steering servo was a nice bonus, brand new JR 8911HV, sweet. Motor is a Novak 55T, looks fairly new.
Electronic's Going in;
Castle Mamba Pro ESC
Castle BEC Pro
Tekin T8 1400kv
3s
1st & 2nd steering axles JR-8711 servos, 403oz @ 6v
3rd steering axle JR 8911HV 470oz @ 7.4
Trans shifting servo JR 650
Servo Winch will be bed mounted w/a boom.
LED's ??
Fat Kid Engineering
06.10.2012, 08:30 PM
The Radio for the project
Fat Kid Engineering
06.10.2012, 08:38 PM
06.10.2012, 09:01 PM
Looking good Jeff.
I had one of those chassis, a while back. Mine had lowly tlt axles and ran a cut down pede tranny with an axi 2217 (1100kv, and about 1" across, tiny motor) on 3s with a mm.
It would almost crawl vertical. Incredible. And I only ran 1.9s. I cannot imagine how your will run with all that power...
06.10.2012, 09:05 PM
So cool! Would love to see one of these full scale ones in person, so much power! =D
Fat Kid Engineering
06.11.2012, 01:31 PM
Originally Posted by lincpimp
Looking good Jeff.
Thanks James, I tested several motors on 2s the results were lack luster at best due to the weight of this pig. At the time of tests there was no body or bed was basically a roller with all electronics and it plumped out at 10.7lbs !
I tried a 55T brushed, 1400kv Outrunner, 1900kv sensored 540 and the power was inadequate. Tho it moved nicely climbing was under powered badly, I also tried a Tekin 550 SC4X 3300kv but it was waaaay to fast. The 1400kv T8 on 3s should prove to be very ballsy and run efficiently.
These trucks have fascinated me since I seen the first video last year, I searched for months befor I found a decent priced used one to start this build. I would love to see them in person myself, I like they way they set up the courses as well. It seems like they purposely try to get them stuck and the crowd cheers all the harder when they can get out.
Reason: typo
06.11.2012, 07:36 PM
bad ass in all aspects, the truck, you brazing that up, super cool my man
Fat Kid Engineering
06.11.2012, 07:43 PM
Thank You much my friend, hang tight have more to post tonight.
Fat Kid Engineering
06.11.2012, 07:47 PM
Fat Kid Engineering
06.11.2012, 07:50 PM
Fat Kid Engineering
06.11.2012, 07:51 PM
The scale winch I bought is really cool but under powered for such a huge machine so I got brave with a brand new Hitec HS7950TH servo and used the scale winch controller to make a bad assed winch with. The servo has 402oz @ 6v so I'm confident it can hack the pig I'm building ?
Now to hit the craft store and score a "bobbin" for a winch reel.
Hybrid Mode
