720i balancing problem
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
720i balancing problem - 06.14.2012, 09:17 AM
I just noticed that once the charge is finished, say at ~20 mins, all cells are between 4.19 and 4.20v, balancer kicks in and tries to balance at end of charge, but it doesn't actually do anything. I will sit there for another 20+ mins trying to balance that 0.01v difference, but sometimes it just increases the cell gap, or takes forever to do it. Has anyone else here had the same problem with their HP charger? It is the older 720i (non-NET3).
This last charge took ~22 mins, and it's currently at 49 mins and still thinking about balancing... it's gone stupid it looks like.
chrismechanic
06.14.2012, 11:06 AM
yer..my e station 902 does this too....worse on older packs....
i have a theory...i think the charger draws off some current after the charge has finnished...so the balancer constanly tries to remedy this.
im sure if you left it long enough it would drain the whole pack down.
all i do is disconnect the pack as soon as it is charged and use it.
chris
jayjay283
jayjay283's Avatar
06.14.2012, 11:26 AM
my 610iduo is doing that too, im not sure if I clicked the alarm off on a channel, or its with my older lipos but it will sound the alarm on 1 i'll take it off and the other keeps screwing around with most cells at 4.2 then 1 screwing with it from 4.19 back to 4.2 down to 4.18 back to 4.2, I eventually just pull it off and run it
06.14.2012, 11:59 AM
I've always noticed that Hyperion balance-chargers and stand-alone balancers tend to be very sensitive to pretty much ANY imbalance. While that's good to a degree, it can worry the inexperienced user that their pack isn't "right".
pinkpanda3310
pinkpanda3310's Avatar
06.14.2012, 07:53 PM
I don't have that charger, I have a cheap chinese one. It is not accurate when balancing and over time I beleive it has gotten slightly worse. Some packs it can balance to with in 0.02v, these are usually packs with less cycles, charged at less amps and don't require a whole lot of balancing to start with.
Other more dodgey packs I have (reclaimed A123's from dewalt battery packs) get to with in 0.05 - 0.07v and will not balance. I am not able to measure the resistance of the cells but I suspect that is what is screwing around with the charger.
That's how I understand it anyway. The different resistance causes the cells to relax to different voltages, when a cell will not hold 4.19 - 4.20v and others will, the charger/balancer is constantly working.
zeropointbug
Z-Pinch racer
06.14.2012, 11:35 PM
Well it looks like I am not the only one with the issue then. It never used to do this up until a few weeks ago, but I thought it was the older packs I had. But I have been trying to put a few light wake up cycles on some new 6s 2200mah 45c G3's. (which, btw, are tiny!)
Some of you are saying that the cells will go up and down; I have some old old A123 packs with balance taps that I tried and the cell imbalance will continue to increase... 0.03v gap....0.06v gap....0.10v gap, it's retarded. The only way I could get them within an acceptable balance was to use a resistor through the balance tap.
I bought a HP Sentry 2, so maybe i'll just use that for balancing the pack will charging, not that a G3 pack will need much balancing anyway.
pinkpanda3310
06.15.2012, 12:22 AM
Yes, I've acheived better results from an external balancer. Though I do lower the charge amps particularly with the A123's so as not to overcharge any cells. The charger will 'charge on' despite any cell differences until the desired pack voltage is reached.
I've never heard of using a resistor on the balance tap. Is that a resistor for every pin on the tap?
zeropointbug
Z-Pinch racer
06.15.2012, 09:26 AM
No, I just use a 10W resistor, plug it into the tap and use a volt meter to watch the voltage until it reaches where I want it, then I move to the next cell.
I was thinking of getting the new 1420i charger, 550w and 20amps, whats not to like... that is, if the sentry balancer cannot keep up with the charge rate
jayjay283
jayjay283's Avatar
06.17.2012, 11:33 AM
Thanks for the words of encouragement bro
zeropointbug
Z-Pinch racer
06.20.2012, 08:56 AM
Well it seems like the charger is smartening up now, the more I use it the better it is working. I will only take a few extra minutes to balance off a pack, I don't understand this, but I like the fact.
chrismechanic
06.20.2012, 10:40 AM
wow...it looks like you stumbled across the worlds first self educating charger
you probably just had a bit of junk in the balancer plug/socket..
chris
zeropointbug
Z-Pinch racer
06.20.2012, 06:53 PM
Who knows... but at least I dont have to buy a new one.
