4wd 1:5 onroad car based on stretched 1:8 truggy chassis
othello
HV basher
4wd 1:5 onroad car based on stretched 1:8 truggy chassis - 10.03.2012, 09:01 PM
I have almost completed my next project which i like to share with you. After having converted 1:8 buggys, truggys, sc-trucks and toying around with 1:10 and 1:8 onroad chassis i thought the next logical step is to step up to 1:5 onroad cars. Living in the city makes it difficult to find a spot for driving a nitro/gas chassis and the performance of a sports 1:5 onroad chassis without a tuning motor/pipe seemed not very appealing to me ... so it had to be brushless. Considering the necessary investment to convert a "true" 1:5 onroad chassis and having seen prices of spare parts led me to the only possible choice: Using proven and reliable 1:8 parts as basis of custom chassis.
I found a used 1:5 onroad body in good condition. I would have prefered a Porsche body but at this time there were no good offers. So i chose a Mercedes touring car body which is depicted here next to my 1:8 and 1:10 bodys.
1:8 buggy tires have almost the same diameter as 1:5 onroad tires but are not as wide. I had good success with GRP Endurance onroad tires on my 1:8 rally game chassis ... so they were my logical choice.
1:8 GRP Endurance tire compared to a GRP 1:5 onroad tire
1:8 Robitronic Mantis truggy axles were a good starting point as they almost instantly gave the right width when paired with my 1:8 tire choice.
With 1:5 GRP tires mounted i have to shorten the arms and cvds by 1.5-2cm to fit the tires under the body.
Next step led me to cut 2 Mantis truggy chassis and joining them to get the right wheelbase
After this step i chose the bruhless components and where to place them on the chassis. Which resulted in this first test layout.
ESC: Xerun 150A Pro
Motor: Castle 1520
Batteries: 2x Turnigy 6s 3600 used in parallel
Steering Servo: Hitec 5955TG
As i was never able to come up with a well balanced custom long CVD (on my previous projects) to join the center diff with the front axle i decided to join those with the aid of a second blocked center diff which required only a short custom CVD/bone. A rather unusual and not very efficient solution but as of yet it has proven to be reliable.
One of the last steps was to find a way to mount the body to the chassis. With some 1:8 parts in my spare bin i came up with this rather simple solution.
With mounted body
After a few test runs with the castle 1520 motor i stepped up to the Castle 1717 motor which was an easy fit when paired with a 22t pinion.
Depending on the batteries i choose the wheight ready to run lies between 6.2 and 6.4Kg (13.7 - 14.1lbs). I'am using lighter Zippy 6s 2800 paired in parallel (depicted on the image above ... the blue ones) or heavier Turnigy 6s 3600 also paired in parallel.
Gear ratio is 1:8.4 with a calculated top speed of 93km/h (58mph) without taking into account tire balloning. By changing the axle ratio from 42/10 (truggy ratio) to 42/12 (buggy ratio) i can augment speed to 110km/h (68mph).
If you wonder how does it perform, well here is a video while testing this setup on a rather small parking lot.
At this point there are still a few things to get done:
. In my opinion the chassis is too flexible and does need a top deck
. I have to come up with a typical 1:5 front bumper
. Damper setup has optimisation potential
snellemin
2 KiloWatt RACER
snellemin's Avatar
10.04.2012, 12:03 PM
Pretty cool man. I'm liking the custom center shaft setup. The vid didn't open for me, but I bet it's a blast to drive.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
10.04.2012, 02:03 PM
The idler diff is a simple solution and should not add much drivetrain drag.
Seems to work v nicely. The truggy suspension should give you sone rally/auto cross options.
othello
HV basher
10.05.2012, 06:02 PM
Small update: i have finished a simple top deck
@snellemin
Vid should work with VLC Player . But i have rendered a WMV video version which should pretty much work on any Windows based pc with Windows Media Player.
Right now i'm only driving this big boy, so yeah you are spot on, it's a blast to drive ;-)
@Arct1k
I have limited suspension travel for onroad use but you are right it should also be a good basis for mild offroading/rallying when adding proper tires and another (rally) body of course. Hmm, have to do some research to find a suitable body. Good idea ...
satttheman
satttheman's Avatar
10.05.2012, 07:55 PM
very nice build!
Projects:
FLM Savage
Semi Pro
Semi Pro's Avatar
10.06.2012, 09:19 PM
nice
Overdriven
Destroyer of Tires
Overdriven's Avatar
10.07.2012, 11:26 PM
Very cool project. You're really getting your money's worth out of that Robitronic Truggy, this being it's second configuration!
othello
HV basher
10.10.2012, 05:18 PM
Video on a wide open space
After 6.5 minutes of top speed passes one of the rear tires was completely run down (and lost its insert). I charged around 4000mAh back which corresponds to an average current of 37A (With 22.2V average power: 820W). To get some decent runtime (10 minutes plus) with an even higher top speed i will need around 8000-10000mAh.
@all
Thanx guys. A truly versatile platform indeed.
othello
HV basher
10.14.2012, 02:20 PM
I have changed gearing to 1:7 and have mounted 1:5 GRP onroad tires which results in a calculated top speed of 110km/h (69mph).
short video from today
As the GRP 1:5 tires provide enough grip i will stay with them for now. I'm happy with the actual speed so gearing should also remain as such. Time to buy some new batteries to bump up run time to 10 minutes plus. 2x 6s 5000 wired in parallel should be the ticket for this target.
Track width is to wide but still works using the mercedes body
ID:	10510   Click image for larger version
10.14.2012, 02:35 PM
I love the looks of the car! I like the track width, I think the wheels look good sitting out a little.
Any chance of posting a video to youtube or something similar, I can't view the videos on a Mac.
othello
HV basher
10.14.2012, 04:33 PM
Thanx _paralized_ . You may install flip4mac on your mac in order to be able to watch WMV Video files. I have reencoded the last video as MP4 file. Quicktime should play it just fine.
Video as MP4 file.
brian015
brian015's Avatar
12.11.2012, 09:13 AM
Othello - I saw this build before but did not get around to commenting - It looks really nice and seems to handle very well.
I like it!
othello
HV basher
12.12.2012, 03:14 AM
I have put together another video. This time i drove the car harder. A lot of sliding on the cold asphalt with harder throttle inputs and braking.
Video links:
WMV Video with eagletree data inserted
MP4 Video with eagletree data inserted
This obviously was harder on the components:
. Motor temperature rises by 26°C (78°F) within 3 minutes. Temperature rise can be as high as 10°C (50°F) per minute.
. On Average up to 60A are drawn out of the batteries per minute. Peak: 182A.
. Resulting in an average of 1,3kW und peak 3,6kW.
. Up to 1000mAh per minute are drawn out of the batteries.
At the end of the video one of the wings at the front of the body had almost detached itself. A result of the "crash" with the snow mound depicted in the previous video.
@Brian015
Thanx Brian. I'm really happy how it handles ... even during winter time when grip is at its lowest.
Big House
Big House's Avatar
01.04.2013, 12:24 AM
How did you fit the 1/5 wheels to your car? Thanks.
CF Ofna DM-1 Pro CC1717
CF Sportswerks Mayhem ST
CF Losi LST2
othello
HV basher
01.06.2013, 08:40 PM
@big house
i bought some FG 18mm square wheel adapters which are 9,5mm wide (part nummer FG6107 i think). They fit perfectly onto the 1:8 truggy axles as they have a 8mm bore and can be tightened onto the axles with 2 6mm grub screws (i never lost one adapter while driving). You can find square wheel adapters with more width (i chose the narrowest i could find). You only have to make sure they feature a 18mm square and have an 8mm bore (i think 8mm axles are common to most 1:8 truggys or buggys).
I'm using a screw and a washer to keep the wheel onto the wheel adapter as the truggy axle comes with a thread. I realy thought i will loose my wheels while driving but this never happened.
ID:	10581   Click image for larger version
