how many cells?
tallyram
tallyram's Avatar
how many cells? - 05.25.2006, 11:57 PM
hey guys, i'm running 6s lipo right now and was wondering how much performance my g2r would loose by going 4s or 5s lipo? by going with less cells i would also like to add more capacity. i'm running a 1950/8 with a 12020. i'd like to make it a little more controllable on the track. also what is a good weight for a g2r? mine seems a little on the heavy side, 12-15lbs im guessing for mine. thanks in advance, carl.
  Send a message via AIM to tallyram
squeeforever
squeeforever's Avatar
05.26.2006, 12:08 AM
With lipo's its more like 11 to 12lbs rtr which is a good weight. I think 5S lipo would still offer GREAT perfermance yet save a little weight and make it a little more controllable on the track.
tallyram
tallyram's Avatar
05.26.2006, 12:13 AM
thanks squee. what config would you suggest to add capacity and stay close to the weight of 6s.
squeeforever
05.26.2006, 12:33 AM
Are you running a 6S2P or 1P configuration? I would go for some backs made up of 4000mah cells in a 3S2P pack and a 2S2P pack for 8000mah.
tallyram
tallyram's Avatar
05.26.2006, 11:03 AM
you asked if i had 2p or 1p config. i wasn't sure so i said i think 1p? then i told you 2 3s packs so you could determine 1p or 2p. i'm running polyquest right now, can i get more in the config you talked about squee?
tallyram
tallyram's Avatar
05.26.2006, 12:42 AM
i think 1p config. 2 3s packs? who makes that config?
squeeforever
05.26.2006, 12:57 AM
What do you mean by 2 3S packs? Is'nt that what your running? I would run one 2S2P and 1 3S2P in series for a total of 5S and 8000mah (if there made of 4000mah cells).
squeeforever
05.26.2006, 12:54 PM
Oh, ok. I understand now. I can't determine whether or not your running a 1P or 2P setup though. Having the mah would help though. There are several companys that make 3S2P and 2S2P packs with either 6000 or 8000mah. maxamps.com for one.
coolhandcountry
coolhandcountry's Avatar
05.26.2006, 03:09 PM
You can buy 2 5s packs from mike and run them parellal for 7400 mah.
squeeforever
05.26.2006, 04:28 PM
Yes, that is an option. Somewhere I heard that it it better to run in series than in parallel for some reason.
coolhandcountry
05.26.2006, 05:05 PM
Well you are going to have 10 cells the other way and 10 cells this way. both are 5s 2p.
squeeforever
05.26.2006, 05:26 PM
Yea, but if I remember correctly it had something to do with them getting out of balance I believe. I think it was something about them being easier to get out of balance if there in parallel.
tallyram
tallyram's Avatar
05.27.2006, 02:59 AM
i don't know. i might just go with 6s polyquest again. this truck is plain awesome to drive. i upgraded the suspension today p2 rockers with the red 7075 pushrods. then i swapped springs and shock oil, purple rear and silver front with 70 weight all around. what do you guys think?:004:
