Opened up the milwaukees and look what I found
DMCfirestar500
Opened up the milwaukees and look what I found - 06.19.2006, 10:43 PM
Well I got one pack with white covered cells and one with brown covered cells. Anyone know if theres a difference?
The brown cells read: Moli FSPE70045.2715 08
The white cells read: Moli FSPE70045.0176 10
I'll ask on some other forums as well and post any findings here.
Pat
squeeforever
squeeforever's Avatar
06.19.2006, 11:43 PM
Thats odd. Are they part # the same?
DMCfirestar500
06.20.2006, 12:30 AM
Well the numbers I listed in the first thread are the numbers on the cells that differ. But below them there is a line that reads IMR-26700A Made in Canada which reads the same on both color cells. I'm hoping that moli just used different color wraps, but the same cells.
cart213
cart213's Avatar
06.20.2006, 12:34 AM
From what I understand, the brown cells use steel positive tabs, and the white ones use aluminum. I don't think it would affect your performance to mix the two.
MetalMan
MetalMan's Avatar
06.20.2006, 01:09 AM
You need special solder flux to solder to aluminum. When you use it, it makes a TON of smoke, like solder smoke times 20!
cart213
cart213's Avatar
06.20.2006, 08:14 AM
I think that the aluminum is plated with something (maybe nickel?) that makes it easier to solder to.
Tazz
Custom
06.20.2006, 08:30 AM
Yes, the aluminum is plated. When you clean them to solder do not remove the plating or you will have to do as MetalMan said.
