Well, I have a couple suggestions. Pro-line Maxx Mashers are good tires for all around use. Also, we will be stocking some tires/wheels from RD-Logics that are similar to the Pro-lines, but cheaper and come premounted. I will let you know how they are when they come in. Personally, I use bow-tie tires modified to fit REVO wheels.
Hi, Mike do you know if the Pro-Line Maxx Masher tires and the Pro-Line Velocity 6 with off-set wheel will be a good set up?
My stock TNX tires make my truck roll over when I turn.
I had Imex Pulto rims with Baja tires.I did not have roll over with them when I turn.But it did seem that my top end was slower with them?
ANY HELP WOULD BE GREAT
Thank you,
Daniel Murray:)
The maxx masher is a great all around tire. I definately recommend the offset wheels as well. This wheel/tire combo will work significantly better than the stock set-up on all surfaces. I have the Maxx Masher tires in stock.
Hi,Mike I brought the Pro-Line Velocity 6 Offset wheels.I am not shore on what tires to go with( Pro-Line maxx masher,Losi Zombie Maxx,Imex Dirt dawg or Imex Trail dawg).If you say Imex then med. or soft compound.
Any Help Would Be Super
Thank You,
Daniel Murray:D :D
I would go with the Zombie maxx or maxx masher tires. They both work well in most conditions. The Zombie maxx is a little heavier and has a stiffer sidewall. Put stiff foams in either and you will be pretty happy.
Hi I think I will go with The Pro-Line Maxx Masher since I have Pro-line Wheels.I let you no soon.
Hmmmm he still hasnt let mike know lol. I heard the zombie maxx tires were good. My best tyres for grip are my 40 series big joes, but my maxx mulchers are nice and light and good on short grass!
:031: :030: :036: :020: :o :026: :028: just playing with the new emoticons lol
