Little question. -
11.18.2006, 10:43 PM
Hey I just got my hyper 7 converted today, and I've got all the hardware mounted. I've got a little problem tho, whenever I start to plug the batteries (12 cells) into my esc (9918) it sparks at the connection. I don't want to try to drive it if it is going to short my batteries or screw up my esc. I just hope I haven't screwed it up yet. Any help would be MUCH appreciated.
11.18.2006, 10:46 PM
Thats normal.
11.18.2006, 11:04 PM
The spark comes from charging up the capacitors on it. No worries.
11.18.2006, 11:07 PM
Alright, I plugged it in and I want to program it now, but I don't hear any beeps or anything. Any ideas?
11.18.2006, 11:19 PM
Did you remove the jumper before you plugged the batteries in?
11.18.2006, 11:23 PM
yep, should i plug it back in, connect batteries, take batts out, and pull out jumper? Maybe to reset it or something?
11.18.2006, 11:25 PM
btw, i cant seem to find the black jumper.
11.18.2006, 11:44 PM
11.19.2006, 12:02 AM
I've seen it... :P I got it to beep, but I'm having a hard time getting it to setup right.
11.19.2006, 12:16 AM
Alright, so I got it programmed, but now when I turn it on, it immediately goes into full throttle, and when i hit the break it revs faster, and hit the throttle it breaks. I think when I first turned it on I stripped the diffs too... :(
11.19.2006, 01:34 AM
Sounds like your throttle channel is reversed. Switch it back and then reprogram it.
11.19.2006, 10:16 AM
Alright I'll try that.. Is there any way to make it just 2wd? cuz I stripped the front diff when I first turned it on...
11.19.2006, 11:17 AM
Alright, well I'm trying to program it now, but right when I plug it in, it beeps, so I hold down the throttle, but it never beeps again.. ?
11.19.2006, 12:16 PM
Alright, I got it working :D. now i just gotta replace some stripped gears...
Hybrid Mode
