Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
READY 2 BUY....Need opinions please....
Procharged5.0
Procharged5.0's Avatar
READY 2 BUY....Need opinions please.... - 12.19.2006, 06:42 PM
I'm finally ready to buy my brushless rig for my Supermaxx E-maxx and want your opinions. Especially from RCM Mike, JHAUTZ, and SERUM (plus anyone else with experience with these products)
I'm looking at one of the two packages:
NEU 1515
UBEC
Mamba Maxx ESC
or
FEIGAO 540C 8XL
UBEC
Mamba Maxx ESC
This will power my Supermaxx Equipped Emaxx. I'll be using GP3300's in 7 or 8 cell configuration (14 or 16 total cells so 1.165x14 = 16.31v or 1.165 * 16 = 18.64v).
I like the NEU 1515 but would rather keep the additional $190 in my pocket if the performance difference between the NEU and the FEIGAO is comparable. Will I need fans for the Feigao? The ESC? The NEU?
I'd consider a Lehner to if it makes more sense.
I'll be converting to Li-Po at some point, probably when the MMM ESC shows up and I can run 6S.
So there it is. Now I need your feedback so I can give Mike an order this week.
What say you????
12.19.2006, 06:58 PM
Jhautz did some testing and found that the 19xx LMTs did much better with the MM than the Neu motors...
Procharged5.0
12.19.2006, 07:00 PM
Can you explain "Better"? Smoother operation? More Speed? What???
12.19.2006, 07:03 PM
Sorry, I thought you might know the thread: http://www.rc-monster.com/forum/show...9&postcount=30
The Neu cogged a lot under hard acceleration, but the LMT was smooth. There's even a video in that post...
coolhandcountry
coolhandcountry's Avatar
12.19.2006, 07:32 PM
I like the lmt motors alot. The neus are nice as well. I have seen some differences between the 4 pole and 2 pole motors in smoothness.
starscream
RC-Monster TQ
starscream's Avatar
12.19.2006, 10:32 PM
Hey CHC, what esc are you running the neu's with?
Ha Ha
jhautz
jhautz's Avatar
12.19.2006, 11:41 PM
If you are planning on running 16 cells on an alloyed out Maxx, I'm not convinced tha tthe MM is the right choice. I think the MM will do nicely in a 8.5lb buggy that is intended to be geared for under 40 for the track, but the bigger/heavier vehicle will draw more amps. The last thing you want is a ESC that is running ragged edge. IMO 16 cells in a maxx size vehicle is ragged edge for the MM. With the little testing I did with the MM I'm not all that thrilled with it as a large scale ESC. DOnt get me wrong...Its amazing that it can do what it does, but I still think you are better off with a speedo that was intended for the job. Read the thread that Brian linked to about what I saw on the MM/Neu combo.
Think about your options for the $ you have to spend.
You could go with the cheaper motor and take the extra $190 from the motor and spend and extra $140 and upgrade the MM to a Quark. Then later when you want to you can upgrade to any motor you want. The quark will run them all and its is still the smoothest esc Ive used. And your still $50 ahaed of the Mamba/Neu combo.
Another thing to consider might be... Right now for like $15 dollars more than the Neu 1515/Mamba combo you could get a Lehner 1940 and Warrior 9920 combo. This would be a killer combo in an emaxx. Heck with the 9920 being only $150 right now, once they go back to regular price($200) you could probably get your $150 back for it by selling it ''gentley'' used on ebay. And then get the MMM when it comes out.
EDIT: Sorry for the book....But you asked.:018:
to make it...
or break it...
Silent...But Deadly
12.19.2006, 11:59 PM
Looks like I'm not the only one with long explanations! ;)
J/K Jhautz. :)
jhautz
jhautz's Avatar
12.20.2006, 12:07 AM
I know... I tend to ramble:010:
to make it...
or break it...
Silent...But Deadly
coolhandcountry
12.20.2006, 01:22 PM
I run the quark 80b with neu 1512 2.5d.
jhautz
jhautz's Avatar
12.20.2006, 04:54 PM
What kind of vehicle? got any weight and gearing info? Just wondering what the 80B can handle.
to make it...
or break it...
Silent...But Deadly
coolhandcountry
12.20.2006, 08:38 PM
At this moment. It is on a 8lb gmaxx with 3.3 stuff on it. Gearing is 14 52 gearing
with stock diffs. I did put an aluminum diff cup in. I run 4s lipo on it.
I had the same set up on a heavier gmaxx with big joes all aluminum
top in at 12lbs. I ran that on 6s with 14 52 gearing. It was alot faster
and had more power. It was just hard to get started on first hook up.
I get more run time now. 8000 and 6000 mah 4s verse 3800 6s .
I have got 45 to 60 mins on 8000 mah batts.
Serum
Serum's Avatar
12.20.2006, 03:11 AM
Pushing the mm with 16 cells is something i would not do.
i have got a Neu and a Lehner, and the Lehner is topnotch stuff. (as is the Neu) since the Lehner is a 2 pole it's easier to be controlled than the Neu for the Mamba Maxx.
If you are planning on running 14-16 cells the 9XL would be a good choice. My 8XL gets relative hot on 16 cells. Doable though, but cooler is nicer IMO.
Perhaps you are better of with getting an MGM16016 controller? or a 9920 with an LVC.
knotted
12.20.2006, 11:10 AM
I can highly recommend the MGM, I have been running it with 5s on a 7xl with no problems at all. The built in voltage cutoff works well too.
Procharged5.0
12.20.2006, 11:19 AM
I can run 12, 14, 0r 16 cell configurations. I built (4) 6-cell packs but have the cells available to make them 7 or 8 cell packs.
I don't want to fry the MM and I know that my 16 cell config is .15v over 5S. I like the programmability of the MM and that its US made but maybe it's not all that necessary to have the PC programmability. OR maybe I should just run 12 or 14 cells.
What is the difference between a LMT 1940 and a LMT 1950?
I have the cash now to do this and want to do it right so the Lehner is an option but if I can get a nice combo without dropping $600+ to do it that would be my preference.
