Another Brushless REVO conversion
Shark413
Shark413's Avatar
Another Brushless REVO conversion - 12.20.2006, 04:56 AM
Hi, my first post here. Every since I got my Revo (nitro) I wanted to convert one to electric power. I have a tricked out E-Maxx but the Revo just handles so much better. I can't wait for Traxxas to make one so I started collecting the parts to convert a nitro Revo to brushless. I finally got enough of the parts to start putting my brushless REVO project together. I was waiting on a custom motor mount (thanks Paul) and it finally arrived this weekend. First, many people who do these conversion use the E-Maxx tranny and motor mounts, I wanted to use the stock Revo tranny with it's auto 2 speed and disk brake. So I needed a special motor mount to use the REVO tranny. I had to machine a stock REVO nitro engine mount to fit onto the new brushless motor mount to give it extra support. The brushless motor puts out a lot of torque and without the extra bracing the chassis flexes way too much.
Here is my Nitro Revo and the roller chassis I am using for the brushless conversion
Here is the custom motor mount
Stock nitro Revo motor mount machined to fit the brushless motor mount
Bottom view of the motor mount
Here is a picture of the chassis with the battery trays mounted
I still need make a plate for the receiver and ESC to sit on (waiting on some carbon fiber stock), I have to install the motor, tires, paint the body and hook up the disk brake. Still have a ways to go but I should soon have it ready for a test run. I would also like to mouint the batteries lower, so I may play around with different mounts to get the CG perfect.
canadianrcist
12.20.2006, 11:01 AM
that looks very nice. good job on it. you could mount those batteries on the underside of the chassis to get a low CG.
http://www.rc-monster.com/forum/show...?t=4725&page=4
i also did a revo conversion.
you could make a mount plate for the esc and attach it to the rear shock tower where the exhuast hold down attaches.
12.20.2006, 11:15 AM
Welcome to the forums!
Nice job on the conversion!
A suggestion? You could try to move your brake servo further forward and make a new brake linkage. This would give you more room on that side for longer batteries, like Lipos. Even if they are on one side, the balance should still be very close since Lipos are lighter and you have the motor and some of the tranny on the other side. You could mount the receiver and ESC on the same side of the motor and you should be golden. Just my $0.02.
Good job!
Shark413
Shark413's Avatar
12.20.2006, 02:37 PM
Thanks for the tips and suggestions, I appreciate your input. Still a work in progress. Sounds like a very knowledgeble group here, so I am sure I will be updating this thread with many more questions.
Regards
Serum
Serum's Avatar
12.20.2006, 04:57 PM
Looks great Shark!
Nice motorholder; looking at the edges, is it lasercutted?
You might need to support the motor to keep it from flexing.
Kyosho batteryholder enable you to hold 7 cells per holder.
jhautz
jhautz's Avatar
12.20.2006, 07:19 PM
Hey Very Nice!!!
Love that motor mount. I was thinking about doing something like that but never got around to it. Do you by any chance have the drawings or a CAD file for a that motor mount? Id love to make one for myself.
to make it...
or break it...
Silent...But Deadly
Shark413
Shark413's Avatar
12.20.2006, 07:45 PM
The motor mount came from a fellow rc monster poster, his URL is www.eaglesviewaerial.com/products.html and he does fantastic CNC machining in metal and carbon fiber.
When I first got his mount I installed it as is, with none of the stock REVO motor mounts. There was a ton of chassis flex, so I decide I needed to also use the stock nitro motor mount brackets and reinforcement brace. I had to mill the nitro mount flat so I could bolt the brushless mount on top of it. Then I added the extra Traxxas reinforcement plate and bolted everything together. After all of that there was no flex at all, but I agree that a motor brace (rear or mid) would really bulletproof the mounting. I think I can machine a small "U" shaped bracket that can fit under the motor, which I can bolt to the mount. This should provide good mid/rear mount support for the motor.
12.20.2006, 11:20 PM
Originally Posted by Shark413
The motor mount came from a fellow rc monster poster, his URL is www.eaglesviewaerial.com/products.html and he does fantastic CNC machining in metal and carbon fiber...
His name is b0gh0s. I was going to have him custom make a motor mount for me for my Revo, but he got too busy. His current mount wouldn't work with the XL motors because they were too long and rear wires would hit the suspension arms due to the mounting height of the motor.
Shark413
Shark413's Avatar
12.21.2006, 02:02 PM
It Lives....
Last night, I mounted the motor and ESC. I moved the battery trays lower, hooked up the brakes and put the tires on. If weather and daylight permit, I will give it a run today. Also, I will try to find my scale and see how heavy it is.
Motor mounted
Completed chassis
Wheels on
Which one is fastest?
b0gh0s
04.18.2007, 04:52 PM
Shark, glad you liked the mount.
Sorry I haven't been around much, primary job has been killing me.
I'm not following on the chassis flex issue and I'd like to better understand what flex you are seeing there. It is probably something easy to fix with the right cross bracing.
I have a few updates to the kit I've made including a mount that moves the ESC up over the rear shocks where fans can get some air (close to the cooling holes in the nitro bodies on the Traxxas lids). When I get a few run off you and the others that have bought get free upgrades (just pay for shipping).
Can you shoot pics and maybe point out where the flex it coming into play?
I've had ZERO issues with the setup flexing on mine but I might not be pushing my machine as hard as you guys do, I just beat around the ramps at the skateboard park near my house and in the front yard.
Shark413
Shark413's Avatar
04.18.2007, 07:23 PM
It's been awhile but I seem to remember that your mount bolts directly to the Revo chassis without using the stock Revo nitro mount. In that configuration I was seeing some flex in the chassis. The Motor kinda hangs out there on two thin pieces of aluminum, and without the nitro mount to tie the motor/mount to the main chassis/diff I was seeing some flex in the chassis (between the motor and the main chassis). I modified the nitro mount so I could use it with your mount and no more flex. Your mount is still going strong and I have a more powerful motor on order. Yeah the tray over the shocks would be great, I am currently running my ESC over the front shocks, but I would prefer it in the rear. The only issue is the Novak ESC with its built in fan is kinda tall.
squeeforever
squeeforever's Avatar
12.20.2006, 10:25 PM
Nice conversion! I am thinking of doing another, very similar. Stock 2 speed, FOC, center diff w/ rear brakes, and 4S LiPo on the right side with the 2 servos and motor on the other.
GorillaMaxx360
GorillaMaxx360's Avatar
12.20.2006, 10:35 PM
Nice conversion
Serum
Serum's Avatar
12.21.2006, 02:06 PM
Hard to tell, which hvmaxx is it? they are not known for their brutal strength, but so is nitro.. :p
coolhandcountry
coolhandcountry's Avatar
12.21.2006, 03:19 PM
Looks nice man.
Peace!
Country
Help support the
Rc-Monster
Buy here
