FD 1/8 Buggy Stutters
BigSushi
FD 1/8 Buggy Stutters - 12.30.2006, 08:00 PM
Hey guys. I picked up a used FD 1/8 Scale buggy. Torn it down and rebuilt it so I know all inerts of the buggy are ok.
Got it all hooked up programmed the 9920 and disabled the BEC, Running a 5 hump 1400mah and a JR AM radio.
Here is the issue: I can ease into the throttle and it goes ok - sometimes even at 1/8th throttle it will stutter (like the motor turns off and then back on). When I attempt full throttle it hesitates like crazy trying to find its self then it will grab but will soon release (stutter or shut off/on the motor) I almost makes a barking sound.
Any ideas?
Thanks
Sylvester
Sylvester's Avatar
12.30.2006, 08:04 PM
What motor? Maybe try a UBEC .
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
BigSushi
12.30.2006, 08:06 PM
The motor is the Nemesis XL. I tried the UBEC on the 9920 but same problem
Sylvester
Sylvester's Avatar
12.30.2006, 08:08 PM
Hmm, i am not positive but it can either be a problem with the motor or esc. Would you possibly have another esc or motor to try out ?
Losi 8ight e
BigSushi
12.30.2006, 08:10 PM
Can I take my MM ESC off my ZX-5 and use that one? If not a wise decision, then no I dont
Sylvester
Sylvester's Avatar
12.30.2006, 08:12 PM
Yes you can, that should be able to tell you and us what the culprit is..
Losi 8ight e
BigSushi
12.30.2006, 08:35 PM
Thanks - but can the MM ESC handle 14.8 Lipo battery ok?
12.30.2006, 09:10 PM
Yes. It handles 12 cells, which is 14.4v nominal, so there is no reason why it won't handle 0.4v more of a 14.8v 4s lipo pack. Even right off the charger, 12 NiMH cells is 16.8v (~1.4v each), which is exactly what 4s lipo is. And then, the ESC has a built-in LVC setting for 4s too.
Sylvester
Sylvester's Avatar
12.30.2006, 09:19 PM
Yea, just dont forget 4s lipo fresh off the charger are (~4.2v each) which is 16.8 so it is equal to 12 cells. Some people have even tried 5S with sucess.
Losi 8ight e
BigSushi
12.30.2006, 09:22 PM
Cool - thanks for the help!!
Sylvester
Sylvester's Avatar
12.30.2006, 09:30 PM
Anytime! - report back when and if you find out what is causing the problem.
Losi 8ight e
coolhandcountry
coolhandcountry's Avatar
12.30.2006, 09:55 PM
Make sure to pull the red wire out of the rx plug.
BigSushi
12.30.2006, 10:45 PM
Ok, got it all hooked and all out of the buggy. All seems to be ok at the moment. I tested forward reverse. Motor gets warm but everything else is cool. It only studdered twice but it is nothing like it was b4. Gotta love the MM esc! Only bad thing I can say about them is - what the hell kind of solder do they use to solder the wires to the board? It took forever to get it to melt!
Aragon
12.30.2006, 11:18 PM
Sounds like you need a larger tip for your iron. Big gauge wiring requires a lot of energy to get it heated up quickly. The only way this happens is by having a large enough tip that can sink its stored energy to what it touches. Bigger (thicker) tip, more stored energy.
12.31.2006, 12:38 AM
The circuit board where the wires enter looks like at least a dual layer board. And, the traces are kinda big and act as a heatsink when you are trying to solder. You have to be careful not to put heat on the solder joint for too long or the heat will travel along the traces and heat up whatever is nearby possibly damaging it. It's better to use a hotter iron for a few seconds than to hold a cooler iron on there longer.
