Feigao 8s and Stampede 6-cells
Tums
Feigao 8s and Stampede 6-cells - 04.23.2005, 05:16 PM
Will this shred the Diff? Plus is says the 8s is 81 amps and the Warrior 7018 is 70 amps, is this a problem?
thunderw0lf
04.23.2005, 05:35 PM
I haven't shredded mine on 6 cells yet but on 7 cells I stripped 2 diffs in less than 5 charges. Course I've only been able to run 2 charges on 6 cells sofar with all the rain we've been getting. And even with 16/84 gearing, my speed meter showed 30 mph top speed so it's much better than stock and will wheelie on 6 even with the added weight of an aluminum brace and RX pack in the front.
MaxxFusion
MaxxFusion's Avatar
04.23.2005, 05:55 PM
You will probaly want to look at the MGM 80 as it has an internal BEC and is cheaper than the 9918. I am going with the MGM 80 and the Lehner 4200 combo for my rusty.
  Send a message via MSN to MaxxFusion
thunderw0lf
04.23.2005, 08:21 PM
I'm pretty sure the 70 amp rating is the continuous rating for the warrior or Mike wouldn't be so fast to recommend it with the 8S. I haven't had any problems with it. Also it does have a BEC but that's only good for 8-10 cells, any more or less and you need an RX pack. However, I'm inclined to agree with Mike that with a Stampede, this is one time adding more weight in the front is a good thing.
