Final decision Quark 125B vs MGM 16cell 160A -
01.15.2007, 08:01 AM
Need to make final decision between controllers for 8XL motor with 14-16cells (do not plan to increase the cell count)
they cost about the same and i just realized that the MGM is a Czech company which would simplify service
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
RC-Monster Captain
01.15.2007, 08:05 AM
The Quark would be my choice, but the MGM is quite good as well. However, you'll get smoother operation out of the quark.
Nice to meet you!
01.15.2007, 08:55 AM
I like my MGM. With your setup you can run it without a fan. I also like the replaceable motor and battery leads. Saves trouble when you constantly abuse your truck!
Breaker of all that is Stock
01.15.2007, 10:40 PM
I've had both, the Quark will overheat without modifacation, the MGM wont but is a real pain to program (unless they have come out with the PC progaming upgrade) and has poor instructions. The Quark is smoother, the MGM more adjustable. I like the Mamba Max the best but it is limited to 4s lipo and 14 cells NIHM if you run a BEC. It also cogs the most at startup. I ran mine for a few high speed passes on 16 cells with no problems but wouldnt advise it. It is also less than half the price of the other controllers:018:
Never fight an ugly man..... he has nothing to loose
01.19.2007, 04:33 AM
thx i just ordered
Neu 1512/2.5D
Quark 125B
5mm mod1 pinion 14T,16T and 18T
Strobe slipper
1x extra strobe slipper pads
51T ofna gear
UBEC
neu endbell
and i have already coming HB diffs + hybrids
cant wait to see faces of nitro guys I go bashing with once in a while :)
Radek
*EX-10 Eurus*
01.20.2007, 01:22 AM
Good choice. Great stup. You'll like it for sure.:027:
to make it...
or break it...
Silent...But Deadly
01.20.2007, 10:20 AM
i have quark have yet to use it but man i can tell you it looks good and there is a LOT of stuff it can do also it has an great warranty
02.01.2007, 04:49 PM
Cant wait till it gets here. hopefully all the stuff arrives next week
Radek
*EX-10 Eurus*
02.01.2007, 05:46 PM
you will like the hb diffs and hybrids but you need a set of bearngs for the pinion for all of them to work 4 bearings actually to accomidate the bigger pinion size.
02.01.2007, 06:29 PM
well i ordered 10 bearings so 2 should be as spare - 4 per diff if i am right
edit//just recieved diffs and they already have 2 bearings so i will actually need just 4 bearing for the pinions
Radek
*EX-10 Eurus*
Hybrid Mode
