would this work...
t-maxxracer32
t-maxxracer32's Avatar
would this work... - 01.28.2007, 11:06 AM
would you be able to wire up AAs and make them work as a battery? like if you went out and bought some of those energizer rechargable batteries...?
was just thinking of it now and i would think it would be a pretty cheap battery for the time being (they wouldnt last too long i wouldnt think)
thanks!
Sylvester
Sylvester's Avatar
01.28.2007, 11:38 AM
They would work, but would suck compared to a normal sub c size battery.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
01.28.2007, 11:41 AM
AA's are very poor at delivering current. They'd work fine for a RX pack, obviously.
Sleeb
Bomb-Proof
01.28.2007, 11:48 AM
you will need around 15 of them in parrallel to make 1 cell. A brushless mini-t draws enough current to pop them.
Sylvester
Sylvester's Avatar
01.28.2007, 11:54 AM
They are only good for transmitters and receiver packs (like sleebus said.)
Losi 8ight e
t-maxxracer32
01.28.2007, 04:15 PM
o well im glad i got that cleared up! thanks as usual for your awsome help!
01.28.2007, 04:54 PM
A while back, I too was curious if AA's could be used in place of single GP3300 cells since they would fit better and have greater capacity when paralleled. So, I took some Duracell 2300mAh AA's, wired a set in parallel for 4600mAh and compared the discharge curve to that of a GP3300 cell. Even with the added capacity, the AA's dropped voltage quite badly after 10A IIRC.
Like others have said, these have good capacity, but only for low-current loads, like a receiver or transmitter pack.
I just saw some fast-charge AA's out recently. Since they charge faster, maybe they have a better discharge curve?
Sylvester
Sylvester's Avatar
01.28.2007, 04:57 PM
Ive seen sony and duracell 15 minute chargers.
Losi 8ight e
01.28.2007, 05:01 PM
Are they recent? Because the store I was at had the regular 2300mAh cells and the "fast-charge" 2300mAh cells of the same maker. Either they are newer cells or just re-labeled...
Sylvester
Sylvester's Avatar
01.28.2007, 05:07 PM
Ive seen them in mid 2006 so i doubt they are new.
Losi 8ight e
