A123 and ice
GorillaMaxx360
GorillaMaxx360's Avatar
A123 and ice - 04.23.2007, 08:49 PM
1.)Hey guys just wondering if the ice can charge the A123's.
2.)Also, i want to know what is the maxx amps (for safety and long life) i can charge the 4600 2s lipo A123 pack.
3.)Can i charge these packs on the ice in 15min like the a123 charger does and how can i do this.
4.)Can i charge these packs through a balancer and with the one mike sells work.
5.)is a balancer needed with these batteries
6.)Is it safe to charge the batteries through the balancer every time.
7.)About how long (time it takes to charge) am i looking at charging these batteries on the ice.
~Anybody do this and any more recommendations~
Thanks guys
MetalMan
MetalMan's Avatar
04.23.2007, 10:37 PM
1. The ICE can charge A123s, it just can't properly terminate the charge on its own. You can get a LipoDapter that will terminate the charge for you, or you can do it manually.
2. You could charge the 4600mah pack at 50amps if you had the right charger.
3. The ICE can't put out enough current to charge a 4600mah pack in 15mins (it would take more than 15amps...)
4. You could use a standard balancer, but I'm not sure if the balancer connectors will line up (I'd guess they won't).
5. The use of a balancer with these batteries is somewhat undecided. A balancer helps, but it's not really necessary since these cells are quite tolerant to overcharge. Using a balancer could increase the life of the cells, though.
6. These batteries are safe, period. A balancer won't really make them any safer, but it could make them last longer (more cycles).
7. At the full 8amps on the ICE, a 2s 4600 would take about 35-40mins.
You could charge up to 5s A123 on the ICE if you run the ICE in NiMh mode, and either manually terminate the charge or have the LipoDapter end the charge automatically.
GorillaMaxx360
04.24.2007, 07:55 AM
what is this lipo adapter.
wallot
wallot's Avatar
04.24.2007, 10:02 AM
lipodapter is a small thingie that u put between charger and A123 pack
http://www.slkelectronics.com/lipodapter/index.htm
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
