Stoopid newby questions :)
pullstarter
Pullstarter
Stoopid newby questions :) - 05.29.2007, 07:54 AM
Hey guys,
Im new to all this BL stuff and am considering converting my Savage X SS. I will probably run 12 cell 4200mah Intelects, what is a good motor and ESC combo for this? Also should I can the steel spur in favour of a plastic one? If so, what gearing do you guys reccomend? Looking at the Kershaw conversion kit and it seems to be pretty decent, any opinions on it?
Sorry to bombard you with questions guys, it's flame a newby time!! :005:
Cheers
simon
gyn77
05.30.2007, 04:16 AM
Hi Pullstarter,
I initially run my savage with 12 cell 4200 intellect and the kit I used was Novak HV 4.5 (750watt), but the absorption of this motor was to big for this batteries and they damaged soon.
You can see a video of my savage with Novak 4.5 (but 4s lipo) here:
http://www.adicesare.altervista.org/video/
IMHO, Better of novak kit (and less expensive too!), I think you could consider a Mamba Max (+ubec) with a feigao 10 or 11XL, but you will not run very very fast.
Otherwise, if you take lipo cells, you could use my equal setup:
mamba max + UBEC
feigao 9XL
lipo 4s maxamps
47t plastic spure gear
16t pinion gear
With this setup, my savage run at max velocity of about 52 km/h (radar gun releved) with good torque.
Don't use a steel spur, the plastic one is better! With a steel spur you can break the pinion ore the motor shaft. (I did it too!)
Sorry me for my bad english.
Alex.
pullstarter
Pullstarter
05.30.2007, 05:08 AM
Thanks very much for the information its much appreciated, i was considering getting into lipo but the cost may be a little hard to take at the moment. Would the 9XL run ok on 2x 2s lipo packs you think? The 3s are a bit beyond my budget :(
gyn77
05.30.2007, 05:29 AM
Yes, I'm sure that if you use 2 x 2s lipo (4s) with feigao 9XL will work great, because I'm using this setup! :005:
If you want isane velocity, then you will have to use 5 or 6s, but at 4s you may be really satisfied!
pullstarter
Pullstarter
05.30.2007, 05:33 AM
I hope its satisfying as my wallet will be very unsatisfied :005: Thanks again for the help :028:
