Pullstarter
Does anyone make a 6 volt/5 amp UBEC? -
06.11.2007, 08:29 AM
As the title says do any manufacturers make a 5 amp/6 volt UBEC? I have very thirsty servos :028: Links would be nice too :018:
cheers
simon
That's All Folks!
06.11.2007, 10:51 AM
About the best I have seen is 3.5 amp. It says it will run 4-6 digital servos. What servos are you running?
06.11.2007, 11:17 AM
IIRC, someone is going to be coming out with a 6A UBEC, but can't remember who. However, you could use two UBECs running at the same time, but it would take some modding to the wiring to do so. Do not simply parallel them unless it is specifically OK to do so (like the Dimension Engineering ones do).
06.11.2007, 11:45 AM
Castle Creations is working on a UBEC that will be able to do something like 10amps burst and take up to 6s Lipo (unless the specs have/will change).
That's All Folks!
06.11.2007, 01:08 PM
Oh yeah, I forgot you can stack the dimension engineering ones.
06.11.2007, 01:18 PM
06.11.2007, 01:23 PM
I like the current rating of that one (if it indeed can put out 5A continuous), but the low V warning is kinda unecessary. Removing the speaker and wire would be the first mod I would do to it. :)
Pullstarter
06.12.2007, 03:19 AM
Thanks for the help guys its much appreciated. Im running a KO 2174 and a JR Z590M, i think 3 amp would probably be enough but thought if there was any 5a on the market i may as well get one. May look into that Integy setup but from previous experience with Integy i'm a bit wary of their claims :eek:
06.12.2007, 09:56 AM
I am using the Koolflight systems Ultimate Ubec, its 3 amp cont. and 5 amp max and does fine for me
Pullstarter
06.12.2007, 06:58 PM
What kind of servos are you using crazy?
06.12.2007, 07:33 PM
That BEC works quite well, maintains a solid 6v, and puts out decent voltage even when overdrawing at ~4.5A. I did a test review of it in the General Electric section.
Pullstarter
06.12.2007, 07:52 PM
I need to find out the stall amps on my KO2174, can't find it anywhere :(
06.12.2007, 09:04 PM
Why do you need the stall amps?
Pullstarter
06.12.2007, 09:28 PM
Want to find out minimum amps it will run on whilst still producing peak torque/speed keeping in mind i'll also be running the JR Z590M for brakes.
06.13.2007, 12:27 PM
right now i'm running a cirrus cs70 200oz servo, its a little slow but the G2R revo turns so fast it doesn't matter. I have run the voltage sensor for my nomadio on it, and no matter how hard i steer it, it never drops below 6v
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
