traxxas titian and mm?
ill_tempered_02
traxxas titian and mm? - 06.17.2007, 09:53 PM
I have a mm hooked up in my stampede and I had it hooked up to a fagio 540 6L. the motor works ok but I don't have spare cells or battery bars to make a 8 cell nimh pack, so I wanted to hook up a traxxas titian because they can handle 14.4 volts. I wired it up to be brushed W/reverse and hooked up the 12 cells. the car took off and wasn't to bad for about 15-20 seconds and then poof the motor started melting. I am wondering why it melted, and how I can run one of these successfully.
crazyjr
crazyjr's Avatar
06.18.2007, 06:20 PM
What are you running for gearing? I would have figured it would run longer than that. How old was the motor? My experience with titans is that they only last about a year no matter how you run them.
one more thing, Was it the 23 turn Emaxx version or the 12 turn rustler/stampede?
ill_tempered_02
06.19.2007, 12:38 AM
I am running the 23 turn emaxx titian and they are old, but have very little use because my emaxx has a hacker b50 10xl in it. they are about 7 years old but have maybe 15-20 packs through it. I have it geared 22/51. thanks
crazyjr
crazyjr's Avatar
06.19.2007, 02:01 AM
How are you running a 51 tooth spur on a stampede? I didn't think they made one, unless you are running a strobe and Mod 1 gears. If thats the case, the mod 1 might not be smooth enough and the added resistence is reeking havoc on the motor. Thats my thoughts. It could be, if there was a 51 tooth spur in 48 pitch for stampede, geared waaaaaaaaaaay too high
ill_tempered_02
06.20.2007, 01:28 AM
i'm using the 32p 51t losi gear
crazyjr
crazyjr's Avatar
06.20.2007, 03:23 AM
the problem i see is that you got a 2.32 ratio on Pinion/spur and 2.72 in tranny, which comes to 6.32:1 total ratio. For stadium trucks you need a 12 to 14:1 ratio total to run proper, so it was my latter suggestion was what happened. Usually that ratio (the one you got now) is usually run in touring cars
ill_tempered_02
06.21.2007, 07:59 PM
do you think that a 17 tooth pinion would be better? or wiring the motor to the hv setup?
I run a fagieo 6l on 6 cells and I use 17/51 and it is cool as can be. I could even put a larger pinion on.
crazyjr
crazyjr's Avatar
06.23.2007, 12:11 PM
It might, I don't know. I never tryed the titan in a stadium truck
