9xl mm revo and lipo temps and ?s
entjoles
9xl mm revo and lipo temps and ?s - 11.04.2007, 04:29 PM
so i ran the revo today and had a hard time charging even after the packs were balanced, had to charge at 1.5 amps, kept unbalanceing(?), any way i dont run extreme settings and i know that as pack v drops it will slow down , but this thing is slow, try to upload video later, bashed like 10 min., oh and it will only do wheelies after i stop and let the caps recharge(?), not very punchy even though i have the punch control dis. , start power is low and the timing is normal
here are the temps:
battery 1(old and 14g wire) 105*f and finished @ 7.38v
battery 2 (maxamps replaced so newer and 12g wire) 85*f @ 7.45v
esc. 85*f
motor 110*f
so i know that this motor is better suited for 5s but i dont want to blow up my mm, and i dont know how to tell if my battery is bad, i have been charging and balancing both packs at once to save time , i even tried the 9l and it was slow to??
any thoughts or suggestions would be great
Matthew_Armeni
Matthew_Armeni's Avatar
11.04.2007, 04:41 PM
I'm a little confused, you running 2 packs at once? 2 2S packs in series? Maybe your old battery is not performing at its best, causing the bad results.
I run my Revo on 4S with a 9XL and get lots of power. You said it's not punchy, what are you geared? Is your top speed ok?
  Send a message via AIM to Matthew_Armeni
squeeforever
squeeforever's Avatar
11.04.2007, 04:48 PM
Running two batteries like that will cause problems...Might wanna get another one to go with your new pack.
entjoles
11.04.2007, 04:53 PM
oh, no!
well i will see what i can do
its geared 20/58, emaxx trans locked in 2nd, i can get other jato spurs at the lhs(56,54) but it is probably the battery, i have not had much success with this truck since i had the battery replaced, so i will look into getting another one
i can basiclly hold it w/o all the time and not worry about it getting crazy, i will start uploading vids
kulangflow
Never Fast Enough
kulangflow's Avatar
11.04.2007, 06:09 PM
I'm running an MM/9XL combo on 4s in my Revo. The emaxx tranny is locked in 2nd also. The only major difference is that I'm running 18/51 mod1 gearing.
Anyway, mine has all kinds of power with that set-up. It wheelies even when it's already going 15 mph or so.
Well, I definitely think it's your batteries. Get another good pack and test it out.
Matthew_Armeni
11.04.2007, 06:12 PM
8XL shouldn't be too hot, but I think once you get your battery situated you'll be happy.
entjoles
11.04.2007, 07:00 PM
i think it must be the battery, but i will have to get a new one and see, i only have the 2 2s packs and one 3s pack so i will have get one, i dont want to try 5s , well thanks , what a bummer
also i noticed when i go to full throttle the lights on the mm are green/orange and the same time??? like neutral and full throttle at the same time, either my lvc is kickin in or i should try to reset it???
entjoles
11.04.2007, 05:56 PM
videos
http://s170.photobucket.com/albums/u...t=MVI_1135.flv
http://s170.photobucket.com/albums/u...t=MVI_1134.flv
if i go to an 8xl will the temps get to hot??
i guess i can just wait for the MMM
