Help with set-up
mustbnitro
Help with set-up - 12.23.2007, 03:45 PM
This is my first 1/8th BL conversion, I have owned 1/18th BL, but am a hardcore newb at 1/8th BL. Yet I have been into 1/8th nitro for a while.
So far I have:
-TL 8ight-t truggy
-RCM mounts and battery box
-True R/C 14.8V 8000MAH pack
-Spectrum DX3.0 with RX and JR9000T servo
-MRC 989 charger
Now I am running into problems with picking out an esc and motor. Either I am going:
-NEU 1515 1Y/F with modded Mamba Max esc
-Wait it out for the Mamba Monster Max esc/ motor combo with their "Neu Designed" 1515 1Y/F
-Go with the NEU 1515 1Y/F and another controller (MGM, quark, etc.)
-I am on somewhat of a budget, but will spend the money for the right set-up, but would rather save as much as I can. I have not been hearing good rumors about the MMM set-up and am not to confident on the release date in a month to month and a half. I was hoping to see manuals, or more specs by now. I am only running for a max of one battery cycle at a time i.e. about 20 minutes. Yet I will be the only guy with a BL truck at the local tracks, but have gotten approval on certain classes. I am open to cheaper set-ups that would get me by (motor/esc combos). I am using it primarily on the track though. Any suggestions would be great.
Serum
Serum's Avatar
12.23.2007, 04:12 PM
I wouldn't hold my breath till castle releases their monstermaxx, that is, if you are planning on running it before this summer.. (this might sound sarcastic, but it's the simple truth)
If you want true power in your buggy, go for the Neu 1515 1y, and an MGM 18120/160 controller. They are available with a dual fan, integrated switching BEC and a healthy support from MGM. the problem with the modified Mambamaxxes is that they cost as much as two mambamaxxes, and a bit more, if you want them converted by GriffinRu (Artur)
What you could do, since this is your first conversion, is get a Feigao/Wanderer type of motor, aim for an 8/9XL for 4S, and see if brushless is your thing. With that setup, you stay well in your budget, since you can simple use a mamba-max controller. Just make sure to get an RC-monster clamp/heatsink for that motor. The endbells tend to fall off for no reason..
mustbnitro
12.23.2007, 09:57 PM
I took a look at the 8XL or 9XL and am thinking of going that route instead of going with a NEU motor, maybe upgrading to the MMM when it does come out. I looked on RCM and they had two or three different types, which one is for me? I am running a truggy so I was hoping to get a little more power for that than is needed in a buggy. Also, the mamba max esc is good for it without modding? I have seen guys "modding" by adding a fan, is that needed? Can I use the BEC with that Mamba max also?
gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
12.24.2007, 01:05 AM
I agree with Serum. I think if you go with a Mamba Max and a XL Feigao motor, you'll have a good idea of what BL is all about. I love my MM/Feigao Revo, wouldn't go back to nitro if you paid me! But, you on the other hand, you could run the MM/Feigao until the MMM comes out or in case you don't like brushless.
I can see in your last post this is what you might do. Go for it!
As far as the fan - Yes and No. I run 4s/9XL/Mamba Max in my Revo and it gets hot, but hasn't thermaled yet. I did add a small 12V fan though, just in case. That will be for the hotter weather, that's all. The other thing I love about the Mamba - Castle Link! Yes, you can use BEC, I recommend the Castle UBEC, no "noise", IE, glitching! My last BEC (Starluck RC) does that. Drives for about 25 feet, then stops.
:D
Patrick
Patrick's Avatar
12.24.2007, 05:37 AM
Another guy at racing uses a mm on 4s in a gorilla/ue maxx with a lenher 1940 7t. He had a fan on it to start with and it worked ok. When the fan broke the mm would thermal before the end of the 5 minute race. He drives with a lot of throttle, so a smoother driving style might not be as bad, but I'd still use a fan. His car's geared for ~35mph.
mustbnitro
12.24.2007, 03:06 PM
Looks like I know what I am getting, what about a 7XL, any links to a good 8XL or 9XL? I am looking at picking up the first two items on this link,http://www.starluckrc.com/catalog/index.php?cPath=52 would this be a good combo? I'm just not sure if the 7XL is alright or not. Thanks for all of the help, I am hoping to get the wheels turning by mid Jan due to a big event.
12.24.2007, 03:11 PM
the 7xl is too high of a kv and will have serious heat issues. www.unitedhobbies.com has a 9xl for $47. best price there is. here os a link
.http://www.hobbycity.com/hobbycity/s...idProduct=4880
also make sure you get this system quickly before your lipo gets old and wont preform as good as it should.
mustbnitro
12.24.2007, 03:23 PM
I did a little searching on the forum and found that on the 7XL, would the RCM 8XL be a good choice http://www.rc-monster.com/proddetail...540C_XL&cat=20, or should I go for that 9XL in the above link, the cases are different and the 9XL is three wire and the 8XL looks like two wire, what is the difference and what would be the most competitive (or better) than nitro? Thanks again for all of the help, I can't wait to get this on the track.
12.24.2007, 03:25 PM
the 8xl would have slightly higher top speed, the 9xl would have slightly better accel, lower temps, and batter runtime.
squeeforever
squeeforever's Avatar
12.25.2007, 04:47 PM
Not true on both accounts. A 7XL, geared appropriately will be fine. You'll lose some runtime though. Only advantage to going with a 8XL will be having lower temps and a wider range of gearing, combination with a little longer runtime. There is NO WAY a 8XL can get faster unless its geared to the moon and gets overly hot. Acceleration will be NOT be better. Also, Lipo's will always perform good...The shelf life is years...Where did you hear that??
Patrick
Patrick's Avatar
12.24.2007, 08:26 PM
All the sensorless brushless motors will have 3 wires, it's probably just the angle of the picture that makes it look like it only has 2.
I wouldn't get a 7XL...well I wouldn't get a 7XL again . Mine got fairly hot in 5 minute races, but the bad part was that it killed 2 quarks because of the power it used. I haven't used the 8 or 9xl, so I'm not really sure what would be better, but I would get the smooth canned version and an rc monster heatsink clamp to stop it falling apart on big impacts.
mustbnitro
12.25.2007, 01:49 PM
I'm going to pick up a 9Xl, with a Mamba Max ESC and a Castle UBEC. I may switch to a 5S lipo, will that MM be able to handle it, or should I stay with 4S? also, will this be competitive with 8th scale nitro truggy? Or will it be blown away by the nitros? I am just wondering if it will have the kick like nitros do hitting a double or clearing a table top. I have a nitro 8ight-t already and I want to run both side by side to see how the conversion is.
mustbnitro
12.25.2007, 02:39 PM
I just tried to order and that 9XL is on back order until late january and I am wanting it ready for a big event in mid january. Is this the same motor in a different label: http://www.rc-monster.com/proddetail...WAND_XL&cat=20
OR: http://www.offshoreelectrics.com/pro...prod=fei-540XL
Any other sitres that have the exact motor united hobbys has on back order for sure has an order coming today or tomorrow. Also, what pinion is everyone running for truggy, I am running 48/13 with nitro, but may be picking up a 46 tooth spur for electric.
gtxracer
gtxracer's Avatar
12.25.2007, 03:40 PM
They're all the same design, just different tags. Get any XL motor from Feigao/Nemesis/Wanderer and you'll be set.
MM/BEC combo is a good one, go with that. If you have the right setup with good tires, it will kick right up the jumps, doubles, whoops, etc. I run my E-Revo on the same setup with 4s and I can get MORE torque than the nitros with the same speed on my track, and my top end is still around 40mph.
:D
gtxracer
gtxracer's Avatar
12.25.2007, 05:52 PM
Yes, but if he plans to upgrade in the future, can 7XL handle 5s+ LiPo? How about the 8XL? I know 9XL is good for the higher LiPo cells.
:D
