any reason noones tried the yuntongs/lifepo4
t-maxxracer32
t-maxxracer32's Avatar
any reason noones tried the yuntongs/lifepo4 - 12.31.2007, 01:24 PM
saw this and it looked pretty interesting.
https://www.unitedhobbies.com/UNITED...idProduct=5632
3.2v
2700 mah
fast charge time
seems like an a123 cell.
when i sell some stuff on in the next couple weeks i might try and pick 10 of these up for a 5s2p setup in my xt8
12.31.2007, 01:29 PM
I'm sure people have. Does seem like an A123 cell. 5s2p would weight in at 28oz (1.75lbs), rated for 16v (3.2v/cell) and 5700mAh, for a price of $115 (plus wire, shrink, etc). Not too bad. If you do get these, make sure to post back here...
t-maxxracer32
12.31.2007, 01:34 PM
lol i sure will.
ive seen one video with these
http://youtube.com/watch?v=0c1kr7EnGV0
imagine that with a neu 1.5d
only reason i am slightly interested in these is because of the fast charge time.
if i can get these charged in 15-20 minutes then run for 15-20 minutes it will be a fun time for me.
Getter Robo
RC Monster Fiberglass
Getter Robo's Avatar
01.01.2008, 09:46 AM
Originally Posted by t-maxxracer32 View Post
lol i sure will.
That's my video BTW :) The performance should have become even better since I switched from stock ATV to GPM Bow-Tie-Style tires and changed the connectors from MPX to Deans.
Those cells have close to 80 amps of discharge in a 2P setup.
Tesla 4 president!
david lamontagn
01.01.2008, 10:41 AM
Just a question about building a 2P A123 style pack:
i want to build a 5s2p, so can i just build 2 independant 5s pack, and after that, simply use the output power leads and connect them in parallel using a "Y" harness make with dean plug???
If YES, could i charge this 5s2p pack using this "Y" harness to charge them in same time on my Hyperion 0610i??
Thank you!
12.31.2007, 01:36 PM
I read some of the user reviews at the bottom, and people are saying it's really just like an A123 cell, and that the capacity is closer to 2300mAh.
12.31.2007, 01:58 PM
I would say that a 10s1p configuration would be a better use of these cells. Good for a HV setup in a mt with a lower kv (1000 or so) motor. Maybe use the oem rc 100a hv esc and A KB 10XL? that united sells, and make the packs fit in and around the existing trans, etc. Would be safe to bash with! Only prob would be a charger that could charge the cells in series.
david lamontagn
12.31.2007, 02:06 PM
Cycle Life: over 1000
Extremely Safe
65mm x 25mm It's long and big Never i'll can place it in my revo batterie tray as a 6s2p configuration, too bad...
t-maxxracer32
12.31.2007, 02:03 PM
ya i read the same about it being like a a123 cell but people were also saying that there is a special way you are supposed to charge these right when you get them.
something about discharging all the way then charging them or something.
anyways we will see soon if i get them.
12.31.2007, 02:20 PM
They are an odd size, just like the A123s, but a bit narrower; you could make a hump pck of sorts I expect from 5 cells.
t-maxxracer32
12.31.2007, 05:06 PM
well ill have to see if i have room before doing anything i guess.
squeeforever
squeeforever's Avatar
12.31.2007, 05:59 PM
There not exactly like A123 cells, but there similar. Metalman has used them for quite some time...
MetalMan
MetalMan's Avatar
01.01.2008, 02:35 AM
A123 cells or the ones this thread is about? I've been using A123 cells for well over a year, and still use my first-ever homemade pack. However, I haven't heard of these 2700mah cells before, or used them for that matter. Perhaps you're confusing them with the 1300mah LiFePO4 cells I was using a couple years ago?
starscream
RC-Monster TQ
starscream's Avatar
01.01.2008, 02:41 AM
I'd be interested to see what the performance difference is between these and the A123's
Ha Ha
squeeforever
01.01.2008, 02:43 AM
Yea, I was refering to the LiFePO4 cells you were using. I didn't know of the mah difference, but either way, there the same type.
