Need advice on a Crt.5 with Feigao 8L
miniGranis
Need advice on a Crt.5 with Feigao 8L - 01.09.2008, 06:17 PM
I might be looking to get a Crt.5 with a Feigao 8L and MambaMax.
The car comes with a 3S 5Ah Maxamps lipo.
Can this be rated as a "good" combo ?
(I have no clue of the Crt.5 figures needed for Brians magiccalculator.)
It's supposed to be geared for about 53 km/h (33 mph), will this setup run hot ? Any ideas on the runtime ?
I also wonder if someone can tell me how it would perform with a 2S setup.
01.09.2008, 06:21 PM
it will work fine, on 3s, will be too slow on 2s. If you give me the pinion size and the tire height I can tell you how fast it will go.
david lamontagn
01.09.2008, 06:45 PM
NO! no!, Linc's not a God, just take a look at this:
http://scriptasylum.com/rc_speed/
01.09.2008, 07:12 PM
I may not be a god, but I do not think that David is a reading teacher either! You must have missed that little bit of info, Dave
GO-RIDE.com
01.09.2008, 08:10 PM
Concensus on RCM is that Mamba Max ESC, 8L motor, and 3S seems to be the sweet spot for the CRT.5. That motor and battery combo geared to only 33mph seems to be well undergeared. If you are driving on a tight track it will be great, but you can easily gear up or run 2.2 truck tires and increase your top speed without much of a heat issue.
My CRT.5 runs a Novak GTB esc, Novak 6.5 (6400kv) motor, and 4800 2S batts. I don't have any heat issues at all and that's geared for 40+mph (46/12 or 13) with 2.2 truck tires. I run a fan on the esc (probably doesn't need it) and no heatsink on the motor. IMO the aluminum motor mount and chassis act as a great heatsink for the motor.
E-8ight - Tekin RX8 2000kv/4S
jhautz
jhautz's Avatar
01.09.2008, 08:25 PM
I run a MM and Hacker 8L (almost identical to the Feiago 8L in kv) on 3s in my CRT.5 and it is a wicked little truck. When bashing or parking lot racing it runs with the 1/8 buggies no problem. I have been running a 20T pinion with no heat issues. Its good for mid 40s.
On the track though the 3s is a bit much. I litterally just throw in a 2s pack and its perfect. No regearing needed.
to make it...
or break it...
Silent...But Deadly
david lamontagn
01.09.2008, 08:32 PM
Oupss sorry! yep i've effectively missed this info
01.09.2008, 08:30 PM
I run a MM with a 7L but smaller 16T pinion on 3s - Runs great...
7L was only because I found a new one going for $22... Couldn't go wrong
miniGranis
01.10.2008, 08:02 AM
Thanks guys.
Quick and straight up answers as always.
