my 5s a123 pack shot? -
01.15.2008, 09:44 PM
i went to the track today and drove my xt8 with no problems and when the battery dumped (dumped instantly) i just drove it up to me and unplugged it.
i get home right now to charge it and it reads 14.8V and it sais output voltage too low so i cant charge it..... i have it set to charge at 8 amps and im using the 1210i to charge it.
anyone know anything i can do?
when i start to charge it it will only charge at about .45 amps then it dies in a couple minutes reading the low output voltage.
thanks!
HOOH HUAH HOOH! Aww Baby!
01.15.2008, 10:09 PM
Check the battery tabs and all connections.
01.15.2008, 10:23 PM
well if the connection was bad it wouldnt make any type of connection at all right?
01.15.2008, 10:25 PM
just an idea - try setting it as a 4s pack to get some volts in it and then swap to 5s...
01.15.2008, 10:31 PM
Just put it in NiMh mode at a couple amps and let it put a couple hundred mAh into the battery. Then it should be good for regular A123 mode.
Yip Yip Yip...
01.15.2008, 10:56 PM
How well do the A123 cells cope with over discharge? I'm wondering as I am going to have some spare cells and I was thinking about sticking 4 in a stock brushed stampede with no cutoff.
01.15.2008, 10:58 PM
well i ran it down to 0% and all i had to do was put it to nimh mode and its back in its normal goodole charging mode now
metalman thanks alot!
i charged it at 14cells for about 3 minutes and the volts shot right up!
its good to go now
Emaxx- FLM wannabe
01.15.2008, 10:59 PM
The hyperion chargers treat it like a lipo, It will only trickle charge if voltage is to low. Either repeat several times until you hit minimum voltage then it will kick into full charge rate to use another method to get it some amps.
1) if you have 2 packs parallel them for a few minutes. Pack 1 will xfer e to Pack 2
2) do like above post say and use NMHI. BUT WATCH IT. if you forget and walk away it will kill pack. Just put like 500 MAH into it then go back to standard charge
OH and your pack is just fine... it does not hurt these things to heavy discharge them :)
PS you would be served well to config your a123 packs into groups of 3 cells.
Then you can Zip charge them. I do that most of the time and if I get LV from hyperion on the occasion that I am using it... I just zip charge for 1 min and then Hyperion works fine.
01.15.2008, 11:03 PM
i feel like the zipcharging method would be hard on your batteries.
or no?
ima pm you and learn more about it.
Emaxx- FLM wannabe
01.15.2008, 11:10 PM
Over on RC groups there is a guy trying to kill his A123 packs. He is charging at 20-30 amps. No problems yet. He is at around 300 cycles now and says the packs at not showing any age.
I personally set my up to charge at around 10-15 amps. No need to charge faster then I will be using them. Since I run 5s, That means I could average 30 AMPS and it would time out perfectly. However I have 3 sets.. and Never run out of charged cells :) I have seen no issues at all and there is a ton of data by everyday flier that say these cells are just not going to fail no matter what you put them through.
Highflier
It
01.15.2008, 11:38 PM
i thought you said it has to be done in 3s sets or w/e?
Emaxx- FLM wannabe
01.15.2008, 11:51 PM
sorry typo..... I meant to say 6s.
E-maxx 9xl, BK warrior, 6s1p A123
Zip charging 15' 18 guage wire
Highflier
01.16.2008, 12:00 AM
Not to sound like a dumb ass, but what is zip charging? Any specific equipment needed? I am guessing that it is a123 only.
01.16.2008, 12:06 AM
lmao!
idk why but i laughed so hard at that
anyways.
heres a link
http://www.rcgroups.com/forums/showthread.php?t=747911
01.16.2008, 12:10 AM
Originally Posted by t-maxxracer32
I guess me sounding like a dumb ass goes without saying...
Thanks for the link, BTW.
Hybrid Mode
