rustler+emaxx wheels and tires
cliccker985
Question rustler+emaxx wheels and tires - 01.21.2008, 02:41 PM
just got a brand brushlees rustler from tower and was wondering if any one has put maxx size wheel and tires on a rustler yet and how did it run??????? is there any company that makes adapters to run that size of tire on a rustler??????? anybody have any pics?????
skellyo
skellyo's Avatar
01.21.2008, 03:32 PM
The best solution I can recommend is this...
ST Racing 14mm hub adapters:
http://www.teamstrc.com/ebproductdet...mainid=1&id=44
RPM Stablemaxx Wheels:
http://www3.towerhobbies.com/cgi-bin...maxx&search=Go
and Panther Komodo Tires:
http://www.rc-monster.com/proddetail.php?prod=PTT140ms
cliccker985
01.21.2008, 03:38 PM
if i decide to run with the maxx size tires what kind of gearing would i run to keep it running cool and around 70mph????how bad would the balloning of the tire be?????
skellyo
skellyo's Avatar
01.21.2008, 03:41 PM
I would drop the gearing to around what the stock VXL stampede uses as a starting point. From there, the temp of the motor/ESC will be the biggest clue as to how to change your gearing. The Komodo tires shouldn't balloon much at all...should be even less than stock VXL Stampede tires would balloon.
cliccker985
01.21.2008, 03:55 PM
i have a brand new set of http://www3.towerhobbies.com/cgi-bin...?&I=LXHGE7&P=7 and http://www3.towerhobbies.com/cgi-bin...?&I=LXHGB6&P=M i was going to put on my emaxx but they look good sittin on rustler.....are these a okay choice for the speed i want to run?????????
skellyo
skellyo's Avatar
01.21.2008, 07:41 PM
I wouldn't run them myself. That's a lot of mass to move with a VXL system. The tires I recommended earlier are probably one of the best choices if you really must have Maxx sized wheels on your Rustler. They are the smallest diameter tire I know of for that situation.
A RC Dude
A RC Dude's Avatar
01.21.2008, 04:43 PM
as for performance, i dion't think it'll be that gears becouse the maxx tires are so big and all. Thare will be a LOT more rotating mass that the motor will haft to deal with. i really dought it'll run more than 60 unless it's gear inproperly. then agian my maxx tires are real old and the newer tires mite be a little lighter(alltho i dought it)!
But, thare's only one way to find out!
tashpop
01.21.2008, 07:55 PM
i just got some grp truggy tires for my emaxx. they are handleing the the balloning problems i was having really well, although i'm not going 70mph. here's a pick. i got them premounted on 17mm rims so you'll need to use 17mm adapters. integy makes a set and they're for sale everywhere. i think you'll get ballooning problems with pretty much any mt tire/wheel combo. you need to look into the truggy tires which are lighter, narrower, some have built in ribs, and have less sidwall to stretch out.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
Just go Play
Just go Play's Avatar
01.22.2008, 03:29 PM
Truggy tires would be the way to go IMO if you are set on running something that big. They are about the same height but narrower and lighter which will help you with both speed and minimizing the load on your drivetrain.
I tried MT tires on my rustler once and that only lasted 10 minutes before I removed them. They make the rustler handle really bad and also made it lift the front end more then usual due to the larger heavier rear wheels.
