an esc for my revo
brushless revo
an esc for my revo - 02.01.2008, 02:20 PM
hi there as you can see im new to the form so hi
right i fried my warrior 9920 and looking for a new esc im torn between the mamba max and the quark 125b monster motor is a 9 xl and batterys at the mo are 12 cells but looking to upgrade to a 5s lipo soon i mainly bash but will be used sometimes at my local track
can any help me lol
ssspconcepts
ssspconcepts's Avatar
02.01.2008, 02:48 PM
can any help me lol
Hi, welcome! I have a quark 125b and it is a good controller, but it is also so awkward to mount...if you are going to spend that kind of loot, I recommend you also consider one of the MGM controllers. I have two of those and I really like them. They have thus far proved to be very robust.
02.01.2008, 02:57 PM
I'd either go cheap with the MM at 58GBP or wait a while for the MMM if you can...
The quarks always bothered me as you still need and UBEC and seem to have to strip the thing apart to do the headsink mod...
A MM will be replaced for 25GBP if you toast it... thats my 2p
Serum
Serum's Avatar
02.01.2008, 02:59 PM
5S might be a tad too much for the MM on the 9XL though.
The MMM can be well worth the wait; A 6S capable combo with a Neu type of motor for 300 usd, sounds unbeatable to me.
brushless revo
02.01.2008, 03:04 PM
the mgm is a little out of my buget im affrade but if i was going to get one is it worth it ie do i need a ubec with it and does it get hot ????
mmm is not out yet im inpatient and really want a esc asap lol
brushless revo
02.01.2008, 03:29 PM
ow and thanks for the quick replys
how long do you think it will take untill the mmm is releasted??????
ssspconcepts
02.01.2008, 03:43 PM
I have two of the MGM22418 (224 amp, 6S) with the internal 6V BEC. Mine stay cool as a cucumbers. A lot of guys run the MGM16018 (160 amp, 6S)and those systems run a little warmer...but I can't speak from personally experience on the 160 amp controllers.
brushless revo
02.01.2008, 03:48 PM
ok thanks
is 4s enuff to power a revo ????? and what would runtimes be if i ran a 4s 5000 oam on mm and 9xl in my revo ?????? mgm are well out of my buget i do like them but £200 is alot compared to £60 for a mm
david lamontagn
02.01.2008, 04:04 PM
I've a e-revo, with Neu 1515, 1Y, MGM 16018 and a 4s, flightpower 5000mAh, and it's verrrrrrrrrrrrrrrrrrrrry powerfull setup, you can believe me
But if i spend some more money next summer i'll buy a 5s or 6s, just for the fun.
On my revo, i'am to remove the entire transmission. I'll only keep the output shaft and make an adaptor to mount a Kyosho 46 spur gear directly on the stock revo output tranny shaft. And i'll use the Tekno rc elektri clutch system to the place of the standart mod1 pinion to allow a little slipping from a dead stop.
Serum
Serum's Avatar
02.01.2008, 03:34 PM
Should be end march. but i wouldn't hold my breath.. you might suffocate..
02.01.2008, 03:42 PM
Hmmm yes it was supposed to be before last summer - but sounding more realy now...
Yes you'd need an ubec and 4s is ok with MM and works ok on a 9XL - I have 3 of those setups on a MBX5T, Revo and X1CR
Serum
Serum's Avatar
02.01.2008, 03:47 PM
But the MGM controllers can also be bought with active cooling nowadays; two fans onto heatsinks, powered from the UBEC i guess. no extra wiring needed. A pretty neat solution IMO. UBEC/LVC/Fans etc all in one. Easy for a clean setup.
02.01.2008, 04:01 PM
4s is fine for powering an E-revo, you'd only want a higher voltage if you were trying to build an endurance basher (long runtimes through lower amp draw/higher voltage).
As for runtimes, check this out for some ideas: CLICKY
I would have thought 15-20minutes or more though with the 9XL on board.
Serum
Serum's Avatar
What an awesome thread you linked to Neil.. Perhaps i should put that data in a datasheet someday..
brushless revo
02.01.2008, 04:28 PM
ok thanks great runtime thread thanks
i really like the specs and price on the quark 125b as i really want to run a 5s for insane run time and power what are your opinoions on the quark with a heat sink and 2 40 mm fans ???? will it be the right esc for me and my 9xl (i may upgrade to neu in future) but i want reliabilty
