Trouble with Neu 1521
BashOn
Trouble with Neu 1521 - 02.02.2008, 11:30 PM
I was setting the mesh today on my Neu 1521 when I realized the motor can was rotating. Basically the outside of the can with twist a little relative to the front plate. Should I be concerned?
I'm thinking I should......
Probably need to send her in......
It doesn't do this easily, its pretty snug.
BP-Revo
BMW M Power!
BP-Revo's Avatar
02.03.2008, 12:25 AM
If I'm not mistaken, Neu's have screwed on endbells. Simply tighten it down, and you should be fine.
t-maxxracer32
t-maxxracer32's Avatar
02.03.2008, 12:27 AM
ya they do.
im always worried mine will twist off but it hasnt yet.
Patrick
Patrick's Avatar
02.03.2008, 12:36 AM
I thought the front end bell and the rest of the can were one piece, on the 1515 anyway.
jhautz
jhautz's Avatar
02.03.2008, 12:53 AM
I'm with you Patrick. The front plate of my Neu is one solid piece with the sides of the can. Just the back plate is a separate piece.
to make it...
or break it...
Silent...But Deadly
MetalMan
MetalMan's Avatar
02.03.2008, 01:00 AM
I thought the same as well, with the rear endbell being pressed in.
Lehner endbells are screwed in, though.
Patrick
Patrick's Avatar
02.03.2008, 01:18 AM
Yeah I think the rear is pressed as well, not screwed. I don't think it could be screwed on or off, because the wires wouldn't let it rotate.
Mine came loose a few months ago. My brother noticed it while the motor was out of the car, nothing happened while driving luckily.
I didn't see any threads on the endbell, so I just put some loctite on and pushed it back it. No problems since.
Maybe the 1521's are different? Because what's happening to BashOn's motor sounds pretty strange.
t-maxxracer32
02.03.2008, 12:54 AM
o i was thinking an endbell was the end of the motor?
sorry i was wrong then. the rear or my motor screws off.
jhautz
jhautz's Avatar
02.03.2008, 12:57 AM
Well screw it back on and use a couple drops of blue locktight so it doesnt do it again.
to make it...
or break it...
Silent...But Deadly
gixxer
gixxer's Avatar
02.03.2008, 03:17 AM
I have a 1521 and the can design looks the same as my 2 1512's. as other have said I believe its one piece and the endbell is pressed on.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
Serum
Serum's Avatar
02.03.2008, 04:20 AM
I would contact Neu over this; i too think the rear is pressed on, and the front/housing is 1 piece?
othello
HV basher
02.03.2008, 04:54 AM
I had to dissassemble my Neu 1512 because the bearings were not running smoothly anymore.
I also noticed that the endbell almost came loose on a few runs. The endbell is only pressed on. Which is rather dissapointing for a high class motor. The front bell/can is one piece. Some days ago after i had changed the bearings the endbell came loose for good and the rotor brushed against the stator.
On the other hand i noticed that on my Neu 1515 (Production date 1/4/2008) Neu Motors changed the design somewhat.
The endbell is now glued in and seems to be secured mecanicaly. There are some small marks around the can where the endbell sits. The bearings now are accessible from the outside. So i guess Neu Motors improved the design. The downside (with the new design) is my RC monster cover for the endbell will fall off.
Serum
Serum's Avatar
02.03.2008, 05:00 AM
Thanks for sharing othello!
lutach
lutach's Avatar
02.03.2008, 03:51 PM
The can of my 1521 is not one peice. Here is a photo of the 1521 and 1527 next to a Lehner 2240. The only thing I don't know if it's screwed or pressed. It might be screwed as mentioned in a post above.
Serum
Serum's Avatar
02.03.2008, 04:29 PM
Ah, yes i see, they are different indeed!
