3s2p vs 3s1p
neweuser
neweuser's Avatar
3s2p vs 3s1p - 02.14.2008, 03:35 PM
If these are the same MAH, can the 1p perform as well as the 2p?
Maxxman
02.14.2008, 03:41 PM
I believe the 1p's voltage would drop more than that of the 2p's under the same load and therefore heat up more.
02.14.2008, 03:58 PM
If the total pack mAh and C are the same, it shouldn't matter. 2p @ 1Ah is the same as 1p @ 2Ah.
However, if the 1p pack is made of one 1Ah cell, and the 2p is made of up two 1Ah cells, the 2p pack will perform better.
neweuser
neweuser's Avatar
02.14.2008, 06:38 PM
So the performance would be the ah of the cells. For example: if the 1p is 1ah, but the 2p is 2ah, obviously the 2p would perform better. But if they are the same ie: 1ah cells, then performance is basically the same. Correct?
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
02.14.2008, 05:15 PM
If the total capacity is the same e.g a 2s2p 2000 mah pack (1000 mah cells) vs. a 2000 mah 2s1p pack, it is better to use the 2s1p pack because bigger cells tend to perform better at high C ratings than smaller cells. Also the chance of getting a bad cell is reduced by 50%.
Area 52 Ranch Raceway
T.R.C.R.
hoober
02.15.2008, 05:57 PM
You can pretty much ignore any reference to P numbers. It is always figured in when describing the capacity and current capability of a pack.
neweuser
neweuser's Avatar
02.15.2008, 06:02 PM
Sounds great. 1p it will be then. :)
Matthew_Armeni
Matthew_Armeni's Avatar
02.15.2008, 06:08 PM
I started a thread on this a little while ago, lots of good information was posted. Check it out here.
Another one about battery setups is here.
Just some info to look at, interesting stuff, enjoy
  Send a message via AIM to Matthew_Armeni
neweuser
neweuser's Avatar
02.18.2008, 02:29 PM
Thanks....'
Edit: that was great info, yes indeed.
Thank you
