How to prevent Sparking when connecting batteries with an MGM controllers -
02.18.2008, 11:05 AM
Hi Guys,
Saw this on the MGM website and think that it will help some of us.
http://mgm-compro.com/pdf/en-antispark-090707.pdf
Will this still work with a Dean's Ultra and how many of us are already doing this?
That's All Folks!
02.18.2008, 11:40 AM
I have mine set up that way. I use a deans plug for the neg(-) and resistor on the pos(+), plug that in first. I have a 5.5 for the main pos(+), and plug that in second.
02.18.2008, 11:43 AM
You have a pic of that? Like they say, a pic is worth a thousand words.. :)
KillaHurtz
02.18.2008, 12:32 PM
I use deans on mine, but I just have a seperate small connector (a 2pin JST plug) that has the resistor. Works really well, esp w/ my HV setup and the really large caps that are on the 9032.
A slight pain as you need an extra connector, but worth it. Just be sure to unplug the xtra plug once fully connected.
02.18.2008, 12:34 PM
its on his muggy link in his sig. nice setup
02.18.2008, 12:46 PM
First, you plug the main "neg" lead. Second, you plug the "by-pass" resistor lead, and third, you plug the main "pos" lead.
On the batterie side, the by-pass lead have a 20 ohms resistor in it. And i use Schulze 3mm bullet for it.
http://img220.imageshack.us/img220/6650/sparkmodfg8.jpg
02.18.2008, 03:37 PM
This type of thing can be done with Deans just as easily (actually, probably easier):
Just hook the mini-deans up first, wait ~10 seconds, then hook up the main leads.
The resistor in the pic above is based on 1,000uF ESC total capacitance and an approximately 10 second charge time. The actual formula for picking the resistor value is:
R = S / 5 / C
R= Resistor in ohms
S= Time in seconds
C= Capacitance in farads
So, if your ESC has three 330uF caps (990uF total) and you want them charged in 5 seconds, the resistor to use would be 1010 ohms, or 1k.
The required resistor power rating can be found by the formula:
P = V^2 / R * 2
P= Power in watts
V= Battery voltage
R= Resistance in ohms
So, for a battery voltage of 22.2v (6s) and a 1k ohm resistor, use a 1W resistor.
KillaHurtz
02.18.2008, 05:27 PM
R = S / 5 / C
R= Resistor in ohms
S= Time in seconds
P = V^2 / R * 2
P= Power in watts
V= Battery voltage
That is basically what I did with mine. However I did not want to use a Deans miniplug as it leaves the possibility of the little prong on the mini connector making contact w/ the main Deans plug. ==> Dead short.
If it was wired carefully to make that impossible then I would feel ok about it. I just don't want any lipo fires in my travel bag I'm carrying my RC stuff around in. Instead I just prefer this:
You can use a smaller resistor, but then you have to get a higher watt rated resistor, and those get big and bulky. I used a 1/2W resistor (as its small and easy to find at ratshack) and an appropriate ohm value. I prolly should get a 1W resistor, but I just have it plugged in a few secs so its fine (its a 2200 IIRC.) Really you just need to take the initial "sting" out of it, and it always takes me a couple of seconds to plug in one, then grab the Deans and plug that in. Spark is tamed by then. Here's a handy calculator
BTW Brian, shouldn't it read [P=V^2/R ]?
02.18.2008, 06:11 PM
True, a totally insulated and polarized mini-connector would be best. The diagram with the mini-Deans was just for demonstration purposes.
Like you said, you don't really need to keep the charging resistor circuit engaged the full amount of time. All you really need is 2/5th the total charge time (which is 86.5%) to take the "sting" out.
And yes, power is V^2 / R, but I always like to add in a little extra heat capacity for safety (factor of 2). But since the duty cycle is so low, you could probably easily get away with V^2 / R * 0.5. I tend to over-engineer.
That's All Folks!
02.18.2008, 04:11 PM
MGM suggests resistor values of 20 to 50 ohm.
02.18.2008, 04:21 PM
I'm sure they recommend those values based on the same capacitance and time-to-charge parameters. 20 ohms on 1000uF total capacitance would take 100ms to charge. It just depends on how long you don't mind waiting.
KillaHurtz
02.18.2008, 09:42 PM
haha, just keepin you on your toes Brian :)
02.18.2008, 10:14 PM
For me, as sonne as the main "pos" lead is plug, i unplug the bypass resistor lead and insulated it.
02.18.2008, 11:15 PM
P O W E R P O L E S
02.19.2008, 12:50 AM
Hi,
This is a very useful thread. I nominate this to be a sticky.
Regards,
Joe Ling
Hyper 9e Medusa 4S, Savage 5S MMM 8XL, Jammin' 4S Neu MMM, X2 Ninja JX, X2 MMM 5S Neu, E REVO Medusa 6S
