MP777 SP2 Brushless -
02.25.2008, 08:52 PM
Ok, so for those of you who viewed my thread questioning buggy weight, here is the beast:
Details:
Kyosho MP777 SP2
Losi 8ight shocks
Ofna Spider center diff
Novak HV4.5 brushless system
Century 9T mod1 Pinion (from Tower Hobbies)
Aluminum Battery Boxes
Pictures:
The buggy currently weights 7.4 lbs without batteries and the battery boxes are designed to fit Maxamps 2s 10000mAh batteries (will hold 2 batteries for 4s total voltage).
Due to the weight issues, I might convince myself of 5000mAh batteries, but the verdict is still out.
I calculated that my battery boxes weight a combined 0.6lbs, so I figure I can thin them out (mill/cut off un-needed sections) and save maybe 0.2 lbs.
I have a few other things I am going to try to save weight with, hopefully getting the buggy down to 7.0 lbs without batteries.
I have yet to finish the battery straps (velcro based) and I still need to mount a short antenna post.
The "o-clamp" motor mounts are from megamotorsusa and I cut the Novak heatsink down and mounted a fan on it to try to keep the heat down.
My plans for this buggy is mostly as a basher, but I also plan to take it to a local track to "race" (they probibly won't let me accumulate point for their championship, but I really just want track time.)
So... How bad is it?
02.25.2008, 09:14 PM
One thing to consider, many of us are using Mamba Max ESCs which weigh 2.5oz. according to Tower. The HV-Maxx ESC weighs 4.8oz. That's a 0.14lb. difference (not enough to account for the weight difference you're seeing, though).
How much does your buggy weigh as a RTR nitro with/without fuel?
02.25.2008, 09:22 PM
First things first..... Ditch those white battery plugs! Get youself some proper deans plugs (or other high current connector).
Other than that it looks like it should do nicely for you. Nice job.
How is that century pinion holding up. I didn't have much luck with those lasting very long against a steel spur. They worked well on the plastic spurs though.
to make it...
or break it...
Silent...But Deadly
02.25.2008, 09:46 PM
Referencing the mamba maxx:
It isn't rated for 4s, and I want to stay within manufacturer recommendations, additionally I am not going to wait for the MMM which was due out 2 years ago initially.
Referencing the connectors:
I will be changing to deans, I just haven't yet.
Referencing the buggy weight in Nitro form:
I don't know, I bought it as a roller but kyosho advertises it as 7.5lb, I do not know if that is with or without fuel.
Edit:
As for the century pinion: I don't know yet, I haven't had this thing running yet, between the cold/snowy weather, and the lack of good batteries, I have yet to turn it on.
Thanks for the input
02.26.2008, 12:08 AM
Edit:
as far as the mamba max goes... its rated for 4s with a suitable BEC... they dont say it in the manual but they imply it in the manual ( i believe it went like anything above 3s, a External Bec is required ) and in fact it works quite well with a nice little novak fan on top of it.
and 7.4 pounds without batterys? damn mine weighed that with batteries if i remember right... ( not sure, but definatly lower than 8 lbs.)
Kyosho 7.5 Kanai 3
Neu 1515 1y/f
Neu 2s 5000 Mah 30c Batteries
M11 DSSS
Airtronics 358
Socal
02.28.2008, 11:33 PM
That diff could be adding some weight. And, your deffinetly going to need a chassis brace in the rear if you plan on jumping this this.
You need to get rid of those Tamiya connectors and get something to handle the amps, like Deans. I can't understand why Novak would put those crap connectors on their brushless system.
02.25.2008, 09:54 PM
I also didn't have much luck with the century pinions on a steel spur. I tried it in my crt.5 and it only lasted 2-3 runs.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
That's All Folks!
02.25.2008, 10:05 PM
I got one run with a century pinion on a steel spur. Get a Kyosho plastic spur or RC-Monster hardened pinion
That's All Folks!
02.29.2008, 02:17 PM
There is always the RC-Monster hardened pinions with a bore adapter for your 1/8th inch shaft. Then they will also work when you go to the 5mm shaft.
02.29.2008, 02:43 PM
I picked up a 12T RC-Monster pinion last week, but I have read that the Novak motors require smaller pinions to prevent overheating, so the 12T will be for if I want to make a speed run or two, while the 9T (if I change to plastic spur) will be for regular usage, unless my results differ.
To update, I have shaved around 1.5 oz (total) off the battery boxes, they look a bit weaker now, but they should be fine, I might even change over to plastic boxes (would save me another 1.5 to 2 Oz.) but that would be either A) more cost or B) lots more time, as I would be machining them at home (using a drill press and dremel).
I have ordered a few more parts:
-CF Diff brace that I will need to trim to fit into place
-front chassis brace (which I will use in the back, hopefully)
-kyosho 46t pinion (will try to modify it to fit the spider for now)
-stronger front shock springs (they are curently using the stock 8ight-T springs, so rear should be ok)
Hopefully, this weekend I will find time to:
-Swap out the battery connectors for deans
-Remake a few of my small aluminum parts out of UHMW (wont crack and ~1/3 as heavy as Alu), that should save me an once or so
-I need to mount the antenna still (probibly use a small piece of UHMW to make a mount)
-Make up my battery straps (I have the materials, but haven't gotten to them yet)
Anyone else notice any small modifications I have yet to do?
TEAM FUSION
03.01.2008, 02:57 AM
For the record, the MM was not even out yet 2 years ago... I would say the MMM is going on a solid year of waiting.
Or has my mind skipped an entire year??
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
03.01.2008, 03:38 AM
how do you adjust the gear mesh on that motor mount? I was jsut looking at it wondering since you picked up a 12T.
to make it...
or break it...
Silent...But Deadly
03.01.2008, 11:46 AM
I would put a spacer under the motor mountr (raise it up).
Or has my mind skipped an entire year?.
I decided to be analytical here so:
I found "coming soon" on message boards dated May 2006,
I found "any news/wait for/I am gonna buy" on message boards dated December 2005,
Still haven't found CC's initial announcement, but they seem to have a track record of announcing things that they haven't even prototyped yet, and then keep pushing back the production dates. Based on the recent posts that claim later this month there is enough hesitation in the wording that makes me expect it won’t be out before June, but I wouldn't be surprised this it took until this fall or later.
I understand that they want to release the best, most reliable product. But they need to not announce things so far in advance, and not keep setting release dates that they can not meet.
So, you are right, 3 years was over exaggerated, I can only trace back 27-28 months of MMM talk.
TEAM FUSION
03.01.2008, 09:35 PM
Wasn't trying to beat you up on it LOL... but let's not forget (I think some here have....) that back in 05-06 they were working on the MM, not the MMM.
They did tell us while they were working on the MM that a MMM version was in their future plans, but never claimed it was anywhere close to being a reality, prior to the release of the MM. Since then... yes we've been waiting.... and it seems like years sometimes...
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
