^Thanks I’ll have to look into that. Personaly I’d prefer the tranny to sit lower as the dogbones closer to level and therefore don’t wear as quickly. Too late for me, if I shim the tranny up I’ll have to hunt for new dogbones (again).
Originally Posted by plettenbergs
i have a chassis and emaxx trani laying around...what rear drive shaft did you use?...where did you get the front one?
Tell you what, I’ll save you trouble and trade-ya strait across for your dual-plet maxx
I used my original UE thunder chassis rear dogbone; then I had to source a front bone. With the tranny mounted flush on the chassis (non-shimmed) a 70mm front dogbone will be perfect. I’m running a 72mm and it’s just a tad tight. Mike can get either 70 or 72mm bones.
